R&S®RTO R&S®RTO oscilloscopes are optimized to perform precise measurements at a high input sensitivity and very low in- Digital Oscilloscope herent noise. The unique high definition mode enables up to 16-bit resolution. With an acquisition rate of up to one million waveforms per second, the R&S®RTO oscilloscopes At a glance detect sporadic signal faults lightning fast. R&S®RTO oscilloscopes are engineered for multi-domain challenges and facilitate debugging of systems with differ- ent signal types. The oscilloscopes enable simultaneous R&S®RTO oscilloscopes combine excellent signal time, frequency, logic and protocol analysis and display fidelity, up to 16-bit vertical resolution and high the results referenced over time. For the first time, a spe- acquisition rate in a compact device format in the cial tool is available for these applications: a zone trigger 600 MHz to 6 GHz class. They offer a fully integrated that can be used in both the time domain and in the fre- quency domain. multi-domain test solution with frequency, proto- col and logic analysis functions. The brilliant R&S®RTO oscilloscopes are extremely easy to use. Gesture touchscreen makes the oscilloscopes very operation simplifies measurement tasks. You can even comfortable to use. customize the waveform display thanks to R&S®SmartGrid technology. The app cockpit provides fast access to all available applications. 2 RTO2000_bro_en_3607-2684-12_v0901.indd 2 23.11.2017 14:54:09
