Datasheet VSE-K96 OFDM Vector Signal Analysis Application (Rohde&Schwarz) - 6
ManufacturerRohde&Schwarz
DescriptionVSE-K96 OFDM Vector Signal Analysis Application Specifications
Pages / Page8 / 6 — Version 01.00, August 2017. Supported instruments. Designation. Type. …
Revision01.00
Version 01.00, August 2017. Supported instruments. Designation. Type. Order No. R&S®FSW 1. R&S®FSV 2. R&S®FSVA 4
Version 01.00, August 2017 Supported instruments Designation Type Order No R&S®FSW 1 R&S®FSV 2 R&S®FSVA 4
For more details, please see the corresponding data sheets.
Designation Type Order No. R&S®FSW 1
Signal and Spectrum Analyzer, 2 Hz to 8 GHz R&S®FSW8 1312.8000.08 Signal and Spectrum Analyzer, 2 Hz to 13.6 GHz R&S®FSW13 1312.8000.13 Signal and Spectrum Analyzer, 2 Hz to 26.5 GHz R&S®FSW26 1312.8000.26 Signal and Spectrum Analyzer, 2 Hz to 43.5 GHz R&S®FSW43 1312.8000.43 Signal and Spectrum Analyzer, 2 Hz to 50 GHz R&S®FSW50 1312.8000.50 Signal and Spectrum Analyzer, 2 Hz to 67 GHz R&S®FSW67 1312.8000.67 Signal and Spectrum Analyzer, 2 Hz to 85 GHz R&S®FSW85 1312.8000.85
R&S®FSV 2
Signal and Spectrum Analyzer, 10 Hz to 4 GHz R&S®FSV4 1321.3008.04 Signal and Spectrum Analyzer, 10 Hz to 7 GHz R&S®FSV7 1321.3008.07 Signal and Spectrum Analyzer, 10 Hz to 13 GHz R&S®FSV13 1321.3008.13 Signal and Spectrum Analyzer, 10 Hz to 30 GHz R&S®FSV30 1321.3008.30 Signal and Spectrum Analyzer, 10 Hz to 40 GHz 3 R&S®FSV40 1321.3008.39 Signal and Spectrum Analyzer, 10 Hz to 40 GHz R&S®FSV40 1321.3008.40
R&S®FSVA 4
Signal and Spectrum Analyzer, 10 Hz to 4 GHz R&S®FSVA4 1321.3008.05 Signal and Spectrum Analyzer, 10 Hz to 7 GHz R&S®FSVA7 1321.3008.08 Signal and Spectrum Analyzer, 10 Hz to 13 GHz R&S®FSVA13 1321.3008.14 Signal and Spectrum Analyzer, 10 Hz to 30 GHz R&S®FSVA30 1321.3008.31 Signal and Spectrum Analyzer, 10 Hz to 40 GHz R&S®FSVA40 1321.3008.41
R&S®RTO1000 5
Digital Oscilloscope, 600 MHz R&S®RTO1002 1316.1000.02 Digital Oscilloscope, 600 MHz R&S®RTO1004 1316.1000.04 Digital Oscilloscope, 1 GHz R&S®RTO1012 1316.1000.12 Digital Oscilloscope, 1 GHz R&S®RTO1014 1316.1000.14 Digital Oscilloscope, 2 GHz R&S®RTO1022 1316.1000.22 Digital Oscilloscope, 2 GHz R&S®RTO1024 1316.1000.24 Digital Oscilloscope, 4 GHz R&S®RTO1044 1316.1000.44
R&S®RTO2000
6 Digital Oscilloscope, 600 MHz, 2 channels R&S®RTO2002 1329.7002.02 Digital Oscilloscope, 600 MHz, 4 channels R&S®RTO2004 1329.7002.04 Digital Oscilloscope, 1 GHz, 2 channels R&S®RTO2012 1329.7002.12 Digital Oscilloscope, 1 GHz, 4 channels R&S®RTO2014 1329.7002.14 Digital Oscilloscope, 2 GHz, 2 channels R&S®RTO2022 1329.7002.22 Digital Oscilloscope, 2 GHz, 4 channels R&S®RTO2024 1329.7002.24 Digital Oscilloscope, 3 GHz, 2 channels R&S®RTO2032 1329.7002.32 Digital Oscilloscope, 3 GHz, 4 channels R&S®RTO2034 1329.7002.34 Digital Oscilloscope, 4 GHz, 4 channels R&S®RTO2044 1329.7002.44 Digital Oscilloscope, 6 GHz, 4 channels R&S®RTO2064 1329.7002.64 1 R&S®FSW firmware version 2.21 or higher required. 2 R&S®FSV firmware version 2.30 or higher required. 3 Max. Bandwidth 10 MHz. 4 R&S®FSVA firmware version 2.30 or higher required. 5 Firmware version 2.51.1.0 and higher required. Firmware 3.50.3.1 and higher recommended. 6 Firmware version 3.50.3.1 and higher required.
6 Rohde & Schwarz
R&S®VSE OFDM Vector Signal Analysis Application
