Increase realtime resolution with 16-bit HD modeResolution as a function of the filter bandwidth The low-noise frontend and single-core A/D converters are FilterResolution the foundation for the high measurement accuracy and Inactive 8 bit dynamic range of the R&S®RTP oscilloscopes. The high 2 GHz 10 bit definition (HD) mode activates configurable low-pass filter- 1 GHz 11 bit ing of the signal after the A/D converters. The hardware 500 MHz 12 bit implemented filters reduce the noise in realtime, effec- 200 MHz to 10 kHz 16 bit tively increasing the signal-to-noise ratio. Users can adjust the filter bandwidth and increase the vertical resolution stepwise. The maximum resolution of 16 bit is achieved at 200 MHz bandwidth. With the Rohde & Schwarz 16-bit HD mode, even the digi- tal trigger system benefits from the increased resolution, making it possible to trigger on the smallest signal details. The 16-bit HD mode makes signals details visible that are otherwise hidden in noise. Rohde & Schwarz R&S®RTP High-Performance Oscilloscope 9 RTP_bro_en_5215-4152_12_v0102.indd 9 07.06.2018 13:43:16
