Frequency Range Square: 0.1 Hz to 15 MHz Pulse: 0.1 Hz to 1 MHz Rise/Fall time <15 ns Overshoot <5% Square Duty Cycle Square: always be 50% /Pulse Pulse: 10% to 90% adjustable Duty Cycle Resolution 1% or 10 ns (whichever is greater) Min. Pulse Width 20 ns Pulse Width Resolution 10 ns or 5 bits (whichever is greater) Jitter 500 ps Frequency Range 0.1 Hz to 100 kHz Ramp Linearity 1% Symmetry 0 to 100% Noise[1] Bandwidth 25 MHz Built-in Waveforms Frequency Range 0.1 Hz to 1 MHz Frequency Range 0.1 Hz to 10 MHz Arbitrary Waveforms Waveform Length 2 to 16k pts Accuracy 100 ppm (lower than 10 kHz) Frequency 50 ppm (greater than 10 kHz) Resolution 0.1 Hz or 4 bit, whichever is greater Output Range 20 mVpp to 5 Vpp, HighZ 10 mVpp to 2.5 Vpp, 50 Ω Amplitude Resolution 100 μV or 3 bit, whichever is greater Accuracy ±(2% of the setting value + 1 mV) (frequency = 1 kHz) Range ±2.5 V, HighZ ±1.25 V, 50 Ω DC Offset Resolution 100 μV or 3 bits, whichever is greater Accuracy ±(2% of the set offset value + 5 mV + 0.5% of the amplitude) Modulation AM, FM General Specifications Probe Compensation Output Output Voltage[1] About 3 V, peak-peak Frequency[1] 1 kHz Power Power Voltage 100 V to 240 V, 45 Hz to 440 Hz Power Maximum 50 W Fuse 2 A, T degree, 250 V Environment Operating: 0℃ to +50℃ Temperature Range Non-operating: -40℃ to +70℃ Cooling Method Fan cooling 0℃ to +30℃ : ≤95℃ relative humidity Humidity Range +35℃ to +40℃ : ≤75℃ relative humidity +40℃ to +50℃ : ≤45℃ relative humidity Operating: under 3,000 meters Altitude Non-operating: under 15,000 meters Mechanical Dimensions[3] Width × Height × Depth = 313.1 mm × 160.8 mm × 122.4 mm Without package 3.2 kg ± 0.2 kg Weight[4] With package 3.8 kg ± 0.5 kg 9 RIGOL
