Datasheet MOC3061M, MOC3062M, MOC3063M, MOC3162M, MOC3163M (ON Semiconductor) - 4
ManufacturerON Semiconductor
Description6-Pin DIP Zero-Cross Triac Driver Optocoupler (600 Volt Peak)
Pages / Page14 / 4 — Stresses exceeding the absolute maximum ratings may damage the device. …
File Format / SizePDF / 444 Kb
Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be
Stresses exceeding the absolute maximum ratings may damage the device The device may not function or be
operable above the recommended operating conditions and stressing the parts to these levels is not recommended.
In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability.
The absolute maximum ratings are stress ratings only. TA = 25°C unless otherwise specified. Symbol Parameters Device Value Unit TOTAL DEVICE
TSTG Storage Temperature All -40 to +150 °C TOPR Operating Temperature All -40 to +85 °C Junction Temperature Range All -40 to +100 °C Lead Solder Temperature All 260 for
10 seconds °C 250 mW 2.94 mW/°C TJ
TSOL
PD Total Device Power Dissipation at 25°C Ambient
Derate Above 25°C All EMITTER
IF Continuous Forward Current All 60 mA VR Reverse Voltage All 6 V 120 mW 1.41 mW/°C PD Total Power Dissipation at 25°C Ambient All Derate Above 25°C DETECTOR
VDRM Off-State Output Terminal Voltage All 600 V ITSM Peak Non-Repetitive Surge Current
(Single Cycle 60 Hz Sine Wave) All 1 A 150 mW 1.76 mW/°C PD Total Power Dissipation at 25°C Ambient All Derate Above 25°C ©2005 Fairchild Semiconductor Corporation
MOC306XM, MOC316XM Rev. 1.5 www.fairchildsemi.com
3 MOC306XM, MOC316XM — 6-Pin DIP Zero-Cross Triac Driver Optocoupler (600 Volt Peak) Absolute Maximum Ratings
