Datasheet MOC3061M, MOC3062M, MOC3063M, MOC3162M, MOC3163M (ON Semiconductor) - 5
ManufacturerON Semiconductor
Description6-Pin DIP Zero-Cross Triac Driver Optocoupler (600 Volt Peak)
Pages / Page14 / 5 — Individual Component Characteristics. Symbol Parameters Test Conditions …
File Format / SizePDF / 444 Kb
Individual Component Characteristics. Symbol Parameters Test Conditions Device Min. Typ. Max. Unit EMITTER
Individual Component Characteristics Symbol Parameters Test Conditions Device Min Typ Max Unit EMITTER
VF Input Forward Voltage IF = 30 mA All 1.3 1.5 V IR Reverse Leakage Current VR = 6 V All 0.005 100 μA MOC306XM 10 500 MOC316XM 10 100 DETECTOR
IDRM1 Peak Blocking Current,
Either Direction VDRM = 600 V, IF = 0(1) dv/dt Critical Rate of Rise of
Off-State Voltage IF = 0 (Figure 11)(2) MOC306XM 600 MOC316XM 1000 nA 1500 V/μs Transfer Characteristics
Symbol IFT VTM
IH DC Characteristics Test Conditions LED Trigger Current Main Terminal
Voltage = 3 V(3) (Rated IFT) Peak On-State Voltage, Either Direction Device Min. Typ. Max. MOC3061M 15 MOC3062M
MOC3162M 10 MOC3063M
MOC3163M 5 ITM = 100 mA peak,
IF = rated IFT Holding Current, Either Direction All 1.8 All 500 3.0 Unit mA V
μA Zero Crossing Characteristics
Symbol VINH IDRM2 Characteristics
Inhibit Voltage (MT1-MT2
voltage above which
device will not trigger) Leakage in Inhibited
State Test Conditions IF = rated IFT Device Typ. Max. MOC3061M
MOC3062M
MOC3063M 12 20 MOC3162M
MOC3163M 12 IF = rated IFT, DRM = 600 V,
off-state Min. Unit V All 15
2 mA Isolation Characteristics
Symbol
VISO Parameter
Isolation Voltage(4) Test Conditions
f = 60 Hz, t = 1 Minute Min. Typ. 4170 Max. Unit
VACRMS RISO Isolation Resistance VI-O = 500 VDC 1011 CISO Isolation Capacitance V = 0 V, f = 1 MHz 0.2 Ω
pF Notes:
1. Test voltage must be applied within dv/dt rating.
2. This is static dv/dt. See Figure 11 for test circuit. Commutating dv/dt is a function of the load-driving thyristor(s) only.
3. All devices are guaranteed to trigger at an IF value less than or equal to max IFT. Therefore, recommended operating
IF lies between max IFT (15 mA for MOC3061M, 10 mA for MOC3062M and MOC3162M, 5 mA for MOC3063M and
MOC3163M) and absolute maximum IF (60 mA).
4. Isolation voltage, VISO, is an internal device dielectric breakdown rating. For this test, pins 1 and 2 are common, and
pins 4, 5 and 6 are common.
©2005 Fairchild Semiconductor Corporation
MOC306XM, MOC316XM Rev. 1.5 www.fairchildsemi.com
4 MOC306XM, MOC316XM — 6-Pin DIP Zero-Cross Triac Driver Optocoupler (600 Volt Peak) Electrical Characteristics
TA = 25°C unless otherwise specified.
