Datasheet ADA4350 (Analog Devices) - 2
DescriptionFET Input Analog Front End with ADC Driver
Pages / Page38 / 2 — ADA4350* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 813 Kb
ADA4350* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADA4350* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADA4350 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADA4350 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Data Sheet
View all ADA4350 EngineerZone Discussions. • ADA4350: FET Input Analog Front End With ADC Driver Data Sheet
SAMPLE AND BUY User Guides
Visit the product page to see pricing options. • UG-655: Evaluating the ADA4350, a FET Input Analog Front End With ADC Driver Offered in a 28-Lead 9.8 mm ×
TECHNICAL SUPPORT
6.4 mm TSSOP Submit a technical question or find your regional support number.
TOOLS AND SIMULATIONS
• ADA4350 SPICE Macro-Model
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
REFERENCE MATERIALS Press
• Integrated Analog Front-end Simplifies Sensor Interfaces
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ±5 V FULL SYSTEM ±5 V FET INPUT AMPLIFIER ±5 V INTERNAL SWITCHING NETWORK AND DIGITAL PINS ±5 V ADC DRIVER 5 V FULL SYSTEM 5 V FET INPUT AMPLIFIER 5 V INTERNAL SWITCHING NETWORK AND DIGITAL PINS 5 V ADC DRIVER TIMING SPECIFICATIONS Timing Diagrams for Serial Mode ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISITICS FULL SYSTEM FET INPUT AMPLIFIER ADC DRIVER TEST CIRCUITS THEORY OF OPERATION KELVIN SWITCHING TECHNIQUES APPLICATIONS INFORMATION CONFIGURING THE ADA4350 SELECTING THE TRANSIMPEDANCE GAIN PATHS MANUALLY OR THROUGH THE PARALLEL INTERFACE SELECTING THE TRANSIMPEDANCE GAIN PATHS THROUGH THE SPI INTERFACE (SERIAL MODE) SPICE MODEL TRANSIMPEDANCE AMPLIFIER DESIGN THEORY TRANSIMPEDANCE GAIN AMPLIFIER PERFORMANCE THE EFFECT OF LOW FEEDBACK RESISTOR RFx USING THE T NETWORK TO IMPLEMENT LARGE FEEDBACK RESISTOR VALUES OUTLINE DIMENSIONS ORDERING GUIDE
