Datasheet AD8001 (Analog Devices)
Description800 MHz, 50 mW Current Feedback Amplifier
Pages / Page17 / 1 — 800 MHz, 50 mW. Current Feedback Amplifier. AD8001. FEATURES. FUNCTIONAL …
RevisionD
File Format / SizePDF / 331 Kb
800 MHz, 50 mW. Current Feedback Amplifier. AD8001. FEATURES. FUNCTIONAL BLOCK DIAGRAMS. Excellent Video Specifications (RL = 150
Datasheet AD8001 Analog Devices, Revision: D
AD8001
a
800 MHz, 50 mW Current Feedback Amplifier AD8001 FEATURES FUNCTIONAL BLOCK DIAGRAMS Excellent Video Specifications (RL = 150 , G = +2) Gain Flatness 0.1 dB to 100 MHz 8-Lead PDIP (N-8), 5-Lead SOT-23-5 0.01% Differential Gain Error CERDIP (Q-8) and SOIC (R-8) (RT-5) 0.025 Differential Phase Error Low Power AD8001 NC 1 8 NC 5.5 mA Max Power Supply Current (55 mW) V 1 5 +V OUT S High Speed and Fast Settling –IN 2 7 V+ –V 2 880 MHz, –3 dB Bandwidth (G = +1) S +IN 3 6 OUT 440 MHz, –3 dB Bandwidth (G = +2) +IN 3 4 –IN V– 4 5 NC 1200 V/ s Slew Rate AD8001 10 ns Settling Time to 0.1% NC = NO CONNECT Low Distortion –65 dBc THD, f
transimpedance linearization circuitry. This allows it to drive
C = 5 MHz 33 dBm Third Order Intercept, F
video loads with excellent differential gain and phase perfor-
1 = 10 MHz –66 dB SFDR, f = 5 MHz
mance on only 50 mW of power. The AD8001 is a current
High Output Drive
feedback amplifier and features gain flatness of 0.1 dB to 100 MHz
70 mA Output Current
while offering differential gain and phase error of 0.01% and
Drives Up to 4 Back-Terminated Loads (75 Each)
0.025°. This makes the AD8001 ideal for professional video
While Maintaining Good Differential Gain/Phase
electronics such as cameras and video switchers. Additionally,
Performance (0.05%/0.25 )
the AD8001’s low distortion and fast settling make it ideal for buffer high speed A-to-D converters.
APPLICATIONS A-to-D Drivers
The AD8001 offers low power of 5.5 mA max (VS = ± 5 V) and
Video Line Drivers
can run on a single +12 V power supply, while being capable of
Professional Cameras
delivering over 70 mA of load current. These features make this
Video Switchers
amplifier ideal for portable and battery-powered applications
Special Effects
where size and power are critical.
RF Receivers
The outstanding bandwidth of 800 MHz along with 1200 V/µs of slew rate make the AD8001 useful in many general-purpose
GENERAL DESCRIPTION
The AD8001 is a low power, high speed amplifier designed high speed applications where dual power supplies of up to ± 6 V to operate on ± 5 V supplies. The AD8001 features unique and single supplies from 6 V to 12 V are needed. The AD8001 is available in the industrial temperature range of –40°C to +85°C.
9 VS = 5V 6 RFB = 820 G = +2 3 RL = 100 0 VS = 5V GAIN – dB –3 RFB = 1k –6 –9 –12 10M 100M 1G FREQUENCY – Hz
Figure 1. Frequency Response of AD8001 Figure 2. Transient Response of AD8001; 2 V Step, G = +2 REV. D Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. No license is granted by implication or otherwise
under any patent or patent rights of Analog Devices. Trademarks and
Tel: 781/329-4700 www.analog.com
registered trademarks are the property of their respective companies.
Fax: 781/326-8703 © 2003 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE MAXIMUM POWER DISSIPATION Typical Performance Characteristics THEORY OF OPERATION Choice of Feedback and Gain Resistors Printed Circuit Board Layout Considerations Power Supply Bypassing DC Errors and Noise Driving Capacitive Loads Communications Operation as a Video Line Driver Driving A-to-D Converters Layout Considerations OUTLINE DIMENSIONS Revision History
