Datasheet ADA4062-2, ADA4062-4 (Analog Devices) - 3
DescriptionLow Power JFET-Input Op Amps
Pages / Page20 / 3 — ADA4062-2/ADA4062-4. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 2. …
File Format / SizePDF / 508 Kb
ADA4062-2/ADA4062-4. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 2. Parameter Symbol. Conditions. Min. Typ. Max. Unit
ADA4062-2/ADA4062-4 SPECIFICATIONS ELECTRICAL CHARACTERISTICS Table 2 Parameter Symbol Conditions Min Typ Max Unit
VSY = ±15 V, VCM = 0 V, TA = 25°C, unless otherwise noted.
Table 2. Parameter Symbol Conditions Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS B Grade (ADA4062-2, 8-Lead SOIC Only) 0.5 1.5 mV −40°C ≤ TA ≤ +125°C 3 mV A Grade 0.75 2.5 mV −40°C ≤ TA ≤ +125°C 5 mV Offset Voltage Drift ∆VOS/∆T −40°C ≤ TA ≤ +125°C 5 μV/°C Input Bias Current IB 2 50 pA −40°C ≤ TA ≤ +125°C 5 nA Input Offset Current IOS 0.5 25 pA −40°C ≤ TA ≤ +125°C 2.5 nA Input Voltage Range −40°C ≤ TA ≤ +125°C −11.5 +15 V Common-Mode Rejection Ratio CMRR B Grade (ADA4062-2, 8-Lead SOIC Only) VCM = −11.5 V to +11.5 V 80 90 dB −40°C ≤ TA ≤ +125°C 80 dB A Grade VCM = −11.5 V to +11.5 V 73 90 dB −40°C ≤ TA ≤ +125°C 70 dB Large-Signal Voltage Gain AVO RL = 10 kΩ, VO = −10 V to +10 V 76 83 dB −40°C ≤ TA ≤ +125°C 72 dB Input Resistance RIN 10 TΩ Input Capacitance, Differential Mode CINDM 1.5 pF Input Capacitance, Common Mode CINCM 4.8 pF OUTPUT CHARACTERISTICS Output Voltage High VOH RL = 10 kΩ to VCM 13 13.5 V −40°C ≤ TA ≤ +125°C 12.5 V Output Voltage Low VOL RL = 10 kΩ to VCM −13.8 −13 V −40°C ≤ TA ≤ +125°C −12.5 V Short-Circuit Current ISC 20 mA Closed-Loop Output Impedance ZOUT f = 1 kHz, AV = 1 1 Ω POWER SUPPLY Power Supply Rejection Ratio PSRR B Grade (ADA4062-2, 8-Lead SOIC Only) VSY = ±4 V to ±18 V 80 90 dB −40°C ≤ TA ≤ +125°C 80 dB A Grade VSY = ±4 V to ±18 V 74 90 dB −40°C ≤ TA ≤ +125°C 70 dB Supply Current per Amplifier ISY IO = 0 mA 165 220 μA −40°C ≤ TA ≤ +125°C 260 μA DYNAMIC PERFORMANCE Slew Rate SR RL = 10 kΩ, CL = 100 pF, AV = 1 3.3 V/μs Settling Time tS To 0.1%, VIN = 10 V step, CL = 100 pF, 3.5 μs RL = 10 kΩ, AV = 1 Gain Bandwidth Product GBP RL = 10 kΩ, AV = 1 1.4 MHz Phase Margin ΦM RL = 10 kΩ, AV = 1 78 Degrees Channel Separation (ADA4062-2 Only) CS f = 1 kHz 135 dB Channel Separation (ADA4062-4 Only) CS f = 1 kHz 130 dB Rev. B | Page 3 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE POWER SEQUENCING ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION NOTCH FILTER HIGH-SIDE SIGNAL CONDITIONING MICROPOWER INSTRUMENTATION AMPLIFIER PHASE REVERSAL SCHEMATIC OUTLINE DIMENSIONS ORDERING GUIDE
