Datasheet AD8018 (Analog Devices)
Description5 V, Rail-to-Rail, High Output Current, xDSL Line Driver Amplifiers
Pages / Page20 / 1 — 5 V, Rail-to-Rail, High-Output Current,. xDSL Line Drive Amplifier. …
RevisionA
File Format / SizePDF / 377 Kb
5 V, Rail-to-Rail, High-Output Current,. xDSL Line Drive Amplifier. AD8018. FEATURES. PIN CONFIGURATIONS
Datasheet AD8018 Analog Devices, Revision: A
a
5 V, Rail-to-Rail, High-Output Current, xDSL Line Drive Amplifier AD8018 FEATURES PIN CONFIGURATIONS Ideal xDSL Line Drive Amplifier for USB, PCMCIA, or PCI-Based Customer Premise Equipment (CPE). The 8-Lead SOIC 14-Lead TSSOP AD8018 provides maximum reach on 5 V supply, (Thermal Coastline) driving 16 dBm of power into a back-terminated, AD8018ARU NC 1 14 NC transformer-coupled 100
while maintaining –82 dBc AD8018AR 1 8 OUT1
V 2 13
V of out-of-band SFDR. S OUT1 S Rail-to-Rail Output Voltage and High Output Current –IN1 3 12 2 7 OUT2 OUT2 –IN1 Drive
IN1 4 11 –IN2 3 6 –IN2
IN1 400 mA Output Current into Differential Load of 10
–V 5 10
IN2 S @ 8 V p-p 4 5 –V
IN2 PWDN1 6 9 PWDN0 S Low Single-Tone Distortion NC 7 8 DGND –86 dBc Worst Harmonic, 6 V p-p into Differential 10
NC = NO CONNECT @ 100 kHz PRODUCT DESCRIPTION Low Noise
The AD8018 is intended for use in single-supply (5 V) xDSL
4.5 nV/
Hz Voltage Noise Density, 100 kHz
modems where high-output current and low distortion are
Out-of-Band SFDR = –82 dBc, 144 kHz to 500 kHz,
essential to achieve maximum reach. The dual high-speed
RLOAD = 12.5
, PLINE = 13 dBm
amplifiers are capable of driving low distortion signals to within
Low-Power Operation
0.5 V of the power supply rail. Each amplifier can drive 400 mA
3.3 V to 8 V Power Supply Range
of current into 10 Ω (differential) while maintaining –82 dBc
Two Logic Bits for Standby and Shutdown
out-of-band SFDR. The AD8018 is available with flexible standby
Low Supply Current of 9 mA/Amplifier (Typ)
and shutdown modes. Two digital logic bits (PWDN1 and
Current Feedback Amplifiers
PWDN0) may be used to put the AD8018 into one of three
High Speed
modes: full power, standby (outputs low impedance), and
130 MHz Bandwidth (–3 dB)
shutdown (outputs high impedance).
300 V/
s Slew Rate
Fabricated with ADI’s high-speed XFCB (eXtra Fast Comple-
mentary Bipolar) process, the high bandwidth and fast slew rate
xDSL USB, PCI, PCMCIA Cards
of the AD8018 keep distortion to a minimum, while dissipat-
Consumer DSL Modems
ing a minimum of power. The quiescent current of the AD8018
Twisted Pair Line Driver
is a low 9 mA/amplifier. The AD8018 drive capability comes in compact 8-lead Thermal Coastline SOIC and 14-lead TSSOP packages. Low-distortion, rail-to-rail output voltage, and high-
–30
current drive in small packages make the AD8018 ideal for use in
N = 4.0
low-cost USB, PCMCIA, and PCI Customer Premise Equipment
–40
for ADSL, SDSL, VDSL, and proprietary xDSL systems. Both
VS = 5V
models will operate over the temperature range –40°C to +85°C.
–50 VS = 3.3V 5V 1nF dBc 0.01
F 100
–60 10
V SFDR S = 8V 10k
R1 10k
3.1
–70 RL = 100
750
V P IN V LINE- REF 750
OUT 16dBm 0.01
F POWER 750
–80 13dBm R2 10k
3.1
1:4 –90 10
TRANSFORMER 4 6 8 10 12 14 16 18 0.01
F 100
10k
PLINE – dBm 1nF
Figure 1. Out-of-Band SFDR vs. ADSL Upstream Line Power; V Figure 2. Single-Supply Voltage Differential Drive Circuit S = 5 V, N = 4 Turns, 144 kHz to 500 kHz. See Evaluation Board Schematics in Figure 11. for xDSL Applications REV. A Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its
use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or
Tel: 781/329-4700 World Wide Web Site: http://www.analog.com
Fax: 781/326-8703 © Analog Devices, Inc., 2000
