Datasheet LTC1407, LTC1407A (Analog Devices) - 4
DescriptionSerial 12-Bit/14-Bit, 3Msps Simultaneous Sampling ADCs with Shutdown
Pages / Page24 / 4 — DIGITAL INPUTS AND DIGITAL OUTPUTS. The. denotes the specifi cations which …
File Format / SizePDF / 408 Kb
DIGITAL INPUTS AND DIGITAL OUTPUTS. The. denotes the specifi cations which apply over the
DIGITAL INPUTS AND DIGITAL OUTPUTS The denotes the specifi cations which apply over the
LTC1407/LTC1407A
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VDD = 3V. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIH High Level Input Voltage VDD = 3.3V l 2.4 V VIL Low Level Input Voltage VDD = 2.7V l 0.6 V IIN Digital Input Current VIN = 0V to VDD l ±10 μA CIN Digital Input Capacitance 5 pF VOH High Level Output Voltage VDD = 3V, IOUT = –200μA l 2.5 2.9 V VOL Low Level Output Voltage VDD = 2.7V, IOUT = 160μA 0.05 V VDD = 2.7V, IOUT = 1.6mA l 0.10 0.4 V IOZ Hi-Z Output Leakage DOUT VOUT = 0V to VDD l ±10 μA COZ Hi-Z Output Capacitance DOUT 1 pF ISOURCE Output Short-Circuit Source Current VOUT = 0V, VDD = 3V 20 mA ISINK Output Short-Circuit Sink Current VOUT = VDD = 3V 15 mA
POWER REQUIREMENTS The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. With internal reference, VDD = 3V. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VDD Supply Voltage 2.7 3.6 V IDD Supply Current Active Mode, fSAMPLE = 1.5Msps l 4.7 7.0 mA Active Mode (LTC1407H/LTC1407AH) l 5.2 8.0 mA Nap Mode l 1.1 1.5 mA Nap Mode (LTC1407H/LTC1407AH) l 1.2 1.8 mA Sleep Mode (LTC1407/LTC1407H) 2.0 15 μA Sleep Mode (LTC1407A/LTC1407AH) 2.0 10 μA PD Active Mode with SCK in Fixed State (Hi or Lo) 12 mW
TIMING CHARACTERISTICS The
fSAMPLE(MAX) Maximum Sampling Frequency per Channel l 1.5 MHz (Conversion Rate) tTHROUGHPUT Minimum Sampling Period (Conversion + Acquisiton Period) l 667 ns tSCK Clock Period (Note 16) l 19.6 10000 ns tCONV Conversion Time (Note 6) 32 34 SCLK cycles t1 Minimum Positive or Negative SCLK Pulse Width (Note 6) 2 ns t2 CONV to SCK Setup Time (Notes 6, 10) 3 10000 ns t3 SCK Before CONV (Note 6) 0 ns t4 Minimum Positive or Negative CONV Pulse Width (Note 6) 4 ns t5 SCK to Sample Mode (Note 6) 4 ns t6 CONV to Hold Mode (Notes 6, 11) 1.2 ns 1407fb 4
