Datasheet LT3060 (Analog Devices) - 8
Description45V VIN, Micropower, Low Noise, 100mA Low Dropout, Linear Regulator
Pages / Page26 / 8 — Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. …
File Format / SizePDF / 446 Kb
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. LT3060-5 Output Voltage. LT3060-15 Output Voltage
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted LT3060-5 Output Voltage LT3060-15 Output Voltage
LT3060
LT3060 Series
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. LT3060-5 Output Voltage LT3060-15 Output Voltage LT3060 ADJ Pin Voltage
5.10 15.30 0.612 IL = 1mA I 15.25 IL = 1mA 0.610 L = 1mA 5.08 VIN = 2.1V 15.20 0.608 5.06 15.15 0.606 5.04 15.10 0.604 5.02 TAGE (V) TAGE (V) 15.05 TAGE (V) 0.602 5.00 15.00 0.600 14.95 0.598 4.98 14.90 0.596 OUTPUT VOL 4.96 OUTPUT VOL ADJ PIN VOL 14.85 0.594 4.94 14.80 0.592 4.92 14.75 0.590 4.90 14.70 0.588 –75 –50 –25 0 25 50 75 100 125 150 175 –75 –50 –25 0 25 50 75 100 125 150 175 –75 –50 –25 0 25 50 75 100 125 150 175 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 3060 G10 3060 G11 3060 G10a
LT3060-1.2 Quiescent Current LT3060-1.5 Quiescent Current LT3060-1.8 Quiescent Current
200 200 200 TJ = 25°C TJ = 25°C TJ = 25°C 175 RL = ∞ 175 RL = ∞ 175 RL = ∞ VOUT = 1.2V VOUT = 1.5V VOUT = 1.8V 150 150 150 125 125 125 100 100 100 75 75 75 VSHDN = VIN VSHDN = VIN VSHDN = VIN QUIESCENT CURRENT (µA) 50 QUIESCENT CURRENT (µA) 50 QUIESCENT CURRENT (µA) 50 25 25 25 VSHDN = 0V VSHDN = 0V VSHDN = 0V 0 0 0 0 1 2 3 4 5 6 7 8 9 10 0 1 2 3 4 5 6 7 8 9 10 0 1 2 3 4 5 6 7 8 9 10 INPUT VOLTAGE (V) INPUT VOLTAGE (V) INPUT VOLTAGE (V) 3060 G12 3060 G13 3060 G14
LT3060-2.5 Quiescent Current LT3060-3.3 Quiescent Current LT3060-5 Quiescent Current
200 200 200 TJ = 25°C TJ = 25°C TJ = 25°C 175 RL = ∞ 175 RL = ∞ 175 RL = ∞ VOUT = 2.5V VOUT = 3.3V VOUT = 5V 150 150 150 125 125 125 100 100 100 75 75 75 VSHDN = VIN VSHDN = VIN VSHDN = VIN QUIESCENT CURRENT (µA) 50 QUIESCENT CURRENT (µA) 50 QUIESCENT CURRENT (µA) 50 25 25 25 VSHDN = 0V VSHDN = 0V VSHDN = 0V 0 0 0 0 1 2 3 4 5 6 7 8 9 10 0 1 2 3 4 5 6 7 8 9 10 0 1 2 3 4 5 6 7 8 9 10 INPUT VOLTAGE (V) INPUT VOLTAGE (V) INPUT VOLTAGE (V) 3060 G15 3060 G16 3060 G17 3060fc 8 For more information www.linear.com/LT3060 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Typical Application Revision History Typical Application Related Parts
