Datasheet LT3062 (Analog Devices) - 2
Description45V VIN, Micropower, Low Noise, 200mA LDO
Pages / Page22 / 2 — absoluTe MaxiMuM raTings (Note 1). pin conFiguraTion. orDer inForMaTion …
absoluTe MaxiMuM raTings (Note 1). pin conFiguraTion. orDer inForMaTion http://www.linear.com/product/LT3062#orderinfo
absoluTe MaxiMuM raTings (Note 1) pin conFiguraTion orDer inForMaTion http://www.linear.com/product/LT3062#orderinfo
LT3062 Series
IN Pin Voltage ...±50V Operating Junction Temperature (Notes 3, 5, 12) OUT Pin Voltage ... +40V, –50V LT3062E, LT3062I.. –40°C to 125°C Input to Output Differential Voltage (Note 2) ...±50V LT3062MP ... –55°C to 150°C ADJ Pin Voltage ..±50V LT3062H .. –40°C to 150°C SHDN Pin Voltage ...±50V Storage Temperature Range .. –65°C to 150°C REF/BYP Pin Voltage .. –0.3V to 1V Lead Temperature (Soldering, 10 sec) Output Short-Circuit Duration .. Indefinite MS8E Package Only ..300°C
pin conFiguraTion
TOP VIEW TOP VIEW REF/BYP 1 8 GND REF/BYP 1 8 GND ADJ 2 7 SHDN 9 ADJ 2 9 7 SHDN OUT GND 3 6 IN OUT 3 GND 6 IN OUT 4 5 IN OUT 4 5 IN MS8E PACKAGE DCB PACKAGE 8-LEAD PLASTIC MSOP 8-LEAD (2mm × 3mm) PLASTIC DFN TJMAX = 150°C, θJA = 29°C/W TO 45°C/W, θJC = 5°C/W TO 10°C/W T EXPOSED PAD (PIN 9) IS GND, MUST BE SOLDERED TO PCB JMAX = 150°C, θJA = 38°C/W TO 45°C/W, θJC = 3.5°C/W EXPOSED PAD (PIN 9) IS GND, MUST BE SOLDERED TO PCB
orDer inForMaTion http://www.linear.com/product/LT3062#orderinfo LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3062EDCB#PBF LT3062EDCB#TRPBF LGNC 8-Lead (2mm × 3mm) Plastic DFN –40°C to 125°C LT3062IDCB#PBF LT3062IDCB#TRPBF LGNC 8-Lead (2mm × 3mm) Plastic DFN –40°C to 125°C LT3062HDCB#PBF LT3062HDCB#TRPBF LGNC 8-Lead (2mm × 3mm) Plastic DFN –40°C to 150°C LT3062MPDCB#PBF LT3062MPDCB#TRPBF LGNC 8-Lead (2mm × 3mm) Plastic DFN –55°C to 150°C LT3062EMS8E#PBF LT3062EMS8E#TRPBF LTGND 8-Lead Plastic MSOP –40°C to 125°C LT3062IMS8E#PBF LT3062IMS8E#TRPBF LTGND 8-Lead Plastic MSOP –40°C to 125°C LT3062HMS8E#PBF LT3062HMS8E#TRPBF LTGND 8-Lead Plastic MSOP –40°C to 150°C LT3062MPMS8E#PBF LT3062MPMS8E#TRPBF LTGND 8-Lead Plastic MSOP –55°C to 150°C LT3062EDCB-3.3#PBF LT3062EDCB-3.3#TRPBF LGYX 8-Lead (2mm × 3mm) Plastic DFN –40°C to 125°C LT3062IDCB-3.3#PBF LT3062IDCB-3.3#TRPBF LGYX 8-Lead (2mm × 3mm) Plastic DFN –40°C to 125°C LT3062EDCB-5#PBF LT3062EDCB-5#TRPBF LGYY 8-Lead (2mm × 3mm) Plastic DFN –40°C to 125°C LT3062IDCB-5#PBF LT3062IDCB-5#TRPBF LGYY 8-Lead (2mm × 3mm) Plastic DFN –40°C to 125°C 3062fa 2 For more information www.linear.com/LT3062
