Datasheet ADAQ7980, ADAQ7988 (Analog Devices)
Description16-bit, 500 kSPS, μModule Data Acquisition System
Pages / Page49 / 1 — 16-Bit, 1 MSPS. μModule Data Acquisition System. Data Sheet. ADAQ7980/. …
RevisionA
16-Bit, 1 MSPS. μModule Data Acquisition System. Data Sheet. ADAQ7980/. ADAQ7988. FEATURES. FUNCTIONAL BLOCK DIAGRAM. Easy to use
Datasheet ADAQ7980, ADAQ7988 Analog Devices, Revision: A
16-Bit, 1 MSPS μModule Data Acquisition System Data Sheet ADAQ7980/ ADAQ7988 FEATURES FUNCTIONAL BLOCK DIAGRAM Easy to use V+ REF REF_OUT LDO_OUT VDD μModule data acquisition system All active components designed by Analog Devices, Inc. 50% PCB area savings PD_REF LDO PD_LDO Includes critical passive components 10µF 2.2µF SPI-/QSPI-/MICROWIRE™-/DSP-compatible serial interface Daisy-chain multiple ADAQ7980/ ADAQ7988 de vices VIO IN+ 20Ω SDI Versatile supply configuration with 1.8 V/2.5 V/3 V/5 V IN– SCK ADC logic interface SDO AMP_OUT High performance CNV 1.8nF 16-bit resolution with no missing codes ADAQ7980/ Throughput: 1 MSPS (ADAQ7980) and 500 k SPS (ADAQ7988) ADAQ7988
01 0
INL: ±8 ppm typical and 20 ppm maximum V– PD_AMP ADCN GND
15060-
SNR: 91.5 dB typical at 10 kHz (unity gain)
Figure 1.
THD: −105 dB at 10 kHz
The ADAQ7980/ADAQ7988 contain a high accuracy, low power,
Zero error: ±0.06 mV typical (unity gain)
16-bit SAR ADC, a low power, high bandwidth, high input
Zero error temperature drift: 1.3 μV/°C maximum
impedance ADC driver, a low power, stable reference buffer,
Low power dissipation
and an efficient power management block. Housed within a tiny,
21 mW typical at 1 MSPS (ADAQ7980)
5 mm × 4 mm LGA package, these products simplify the design
16.5 mW typical at 500 kSPS (ADAQ7988)
process for data acquisition systems. The level of system integration
Flexible power-down modes
of the ADAQ7980/ADAQ7988 solves many design challenges,
Small, 24-lead, 5 mm × 4 mm LGA package
while the devices still provide the flexibility of a configurable
Excellent ESD ratings
ADC driver feedback loop to allow gain and/or common-mode
3500 V human body model (HBM)
adjustments. A set of four device supplies provides optimal system
1250 V field-induced charged device model (FICDM)
performance; however, single-supply operation is possible with
Wide operating temperature range: −55°C to +125°C
minimal impact on device operating specifications.
The ADAQ7980/ADAQ7988 integrate within a compact,
Automated test equipment (ATE)
integrated circuit (IC)-like form factor key components
Battery powered instrumentation
commonly used in data acquisition signal chain designs. The
Communications
μModule family transfers the design burden of component
Data acquisition
selection, optimization, and layout from designer to device,
Process control
shortening overall design time, system troubleshooting, and
Medical instruments
ultimately improving time to market.
GENERAL DESCRIPTION
The serial peripheral interface (SPI)-compatible serial interface features the ability to daisy-chain multiple devices on a single, 3- The ADAQ7980/ADAQ7988 are 16-bit analog-to-digital converter wire bus and provides an optional busy indicator. The user (ADC) μModule® data acquisition systems that integrate four interface is compatible with 1.8 V, 2.5 V, 3 V, or 5 V logic. common signal processing and conditioning blocks into a system in package (SiP) design that supports a variety of applications. Specified operation of these devices is from −55°C to +125°C. These devices contain the most critical passive components,
Table 1. Integrated SAR ADC μModules
eliminating many of the design challenges associated with
Type 500 kSPS 1000 kSPS
traditional signal chains that use successive approximation 16-Bit ADAQ7988 ADAQ7980 register (SAR) ADCs. These passive components are crucial to achieving the specified device performance.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL-SUPPLY CONFIGURATION SINGLE-SUPPLY CONFIGURATION TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL DATA THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION Transfer Functions TYPICAL CONNECTION DIAGRAM ADC DRIVER INPUT INPUT PROTECTION NOISE CONSIDERATIONS AND SIGNAL SETTLING OPERATION DYNAMIC POWER SCALING (DPS) SLEW ENHANCEMENT EFFECT OF FEEDBACK RESISTOR ON FREQUENCY RESPONSE VOLTAGE REFERENCE INPUT POWER SUPPLY LDO REGULATOR CURRENT-LIMIT AND THERMAL OVERLOAD PROTECTION LDO REGULATOR THERMAL CONSIDERATIONS DIGITAL INTERFACE 3-WIRE MODE WITHOUT THE BUSY INDICATOR 3-WIRE MODE WITH THE BUSY INDICATOR 4-WIRE MODE WITHOUT THE BUSY INDICATOR 4-WIRE MODE WITH THE BUSY INDICATOR CHAIN MODE WITHOUT THE BUSY INDICATOR CHAIN MODE WITH THE BUSY INDICATOR APPLICATION CIRCUITS NONUNITY GAIN CONFIGURATIONS INVERTING CONFIGURATION WITH LEVEL SHIFT USING THE ADAQ7980/ADAQ7988 WITH ACTIVE FILTERS APPLICATIONS INFORMATION LAYOUT EVALUATING THE PERFORMANCE OF THE ADAQ7980/ADAQ7988 OUTLINE DIMENSIONS ORDERING GUIDE
