Datasheet AD7666 (Analog Devices) Manufacturer Analog Devices Description 16-Bit, 500 kSPS PulSAR® Unipolar ADC with Ref Pages / Page 29 / 1 — 16-Bit 500 kSPS PulSAR®. Unipolar ADC with Reference. AD7666. FEATURES. … File Format / Size PDF / 568 Kb Document Language English
16-Bit 500 kSPS PulSAR®. Unipolar ADC with Reference. AD7666. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Model Line for this Datasheet Text Version of Document 16-Bit 500 kSPS PulSAR® Unipolar ADC with Reference AD7666 FEATURES FUNCTIONAL BLOCK DIAGRAM 2.5 V internal reference: typical drift 3 ppm/°C REFBUFIN REF REFGND DVDD DGND Guaranteed max drift 15 ppm/°C AGND OVDD Throughput: 500 kSPS AD7666 AVDD SERIAL OGND INL: ±2.0 LSB max (±0.0038% of full scale) REF PORT 16-bit resolution with no missing codes 16 IN SWITCHED DATA[15:0] S/(N+D): 88 dB min @ 20 kHz CAP DAC INGND BUSY THD: –96 dB max @ 20 kHz PARALLEL PDREF INTERFACE RD Analog input voltage range: 0 V to 2.5 V PDBUF CLOCK CS Both AC and DC specifications PD CONTROL LOGIC AND SER/PAR RESET No pipeline delay CALIBRATION CIRCUITRY OB/2C Parallel and serial 5 V/3 V interface 001 0-BYTESWAP SPI®/QSPITM/MICROWIRETM/DSP compatible 03034-CNVST Single 5 V supply operation Figure 1. Functional Block DiagramPower dissipation 66 mW typ, 132 µW @ 1 kSPS without REF Table 1. PulSAR Selection 81 mW typ with REF 800– 48-lead LQFP and 48-lead LFCSP packages Type/kSPS 100–250 500–570 1000 Pin-to-pin compatible with PulSAR ADCs Pseudo- AD7651 AD7650/AD7652 AD7653 Differential AD7660/AD7661 AD7664/AD7666 AD7667APPLICATIONS True Bipolar AD7663 AD7665 AD7671Data acquisition True AD7675 AD7676 AD7677Medical instruments DifferentialDigital signal processing 18-Bit AD7678 AD7679 AD7674Spectrum analysis Multichannel/ AD7654Instrumentation Simultaneous AD7655Battery-powered systems Process control PRODUCT HIGHLIGHTS 1. Fast Throughput.GENERAL DESCRIPTION The AD7666 is a 500 kSPS, charge redistribution, 16-bit SAR ADC with internal error correction circuitry. The AD7666 is a 16-bit, 500 kSPS, charge redistribution SAR analog-to-digital converter that operates from a single 5 V 2. Superior INL. power supply. The part contains a high speed, 16-bit sampling The AD7666 has a maximum integral nonlinearity of ADC, an internal conversion clock, internal reference, error 2.0 LSB with no missing 16-bit codes. correction circuits, and both serial and parallel system inter- 3. Internal Reference. face ports. The AD7666 is hardware factory-calibrated and The AD7666 has an internal reference with a typical comprehensively tested to ensure ac parameters such as signal- temperature drift of 3 ppm/°C. to-noise ratio (SNR) and total harmonic distortion (THD), in 4. Single-Supply Operation. addition to the more traditional dc parameters of gain, offset, The AD7666 operates from a single 5 V supply. Its power and linearity. dissipation decreases with throughput. The AD7666 is available in a 48-lead LQFP and a tiny 48-lead 5. Serial or Parallel Interface. LFCSP, with operation specified from –40°C to +85°C. Versatile parallel or 2-wire serial interface arrangement is compatible with both 3 V and 5 V logic.Rev. 0 Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. or otherwise under any patent or patent rights of Analog Devices. Trademarks and Tel: 781.329.4700 www.analog.com registered trademarks are the property of their respective owners. Fax: 781.326.8703 © 2004 Analog Devices, Inc. All rights reserved. Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS DEFINITIONS OF SPECIFICATIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT INFORMATION CONVERTER OPERATION Transfer Functions TYPICAL CONNECTION DIAGRAM Analog Input Driver Amplifier Choice Voltage Reference Input Power Supply POWER DISSIPATION VERSUS THROUGHPUT CONVERSION CONTROL DIGITAL INTERFACE PARALLEL INTERFACE SERIAL INTERFACE MASTER SERIAL INTERFACE Internal Clock SLAVE SERIAL INTERFACE External Clock External Discontinuous Clock Data Read After Conversion External Clock Data Read During Conversion MICROPROCESSOR INTERFACING SPI Interface (ADSP-219x) APPLICATION HINTS BIPOLAR AND WIDER INPUT RANGES LAYOUT EVALUATING THE AD7666’S PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
