Datasheet AD7666 (Analog Devices) - 4
Description16-Bit, 500 kSPS PulSAR® Unipolar ADC with Ref
Pages / Page29 / 4 — AD7666
File Format / SizePDF / 568 Kb
AD7666
AD7666
link to page 4 link to page 5 link to page 5 link to page 5 link to page 5
AD7666 SPECIFICATIONS Table 2. –40°C to +85°C, AVDD = DVDD = 5 V, OVDD = 2.7 V to 5.25 V, unless otherwise noted Parameter Conditions Min Typ Max Unit
RESOLUTION 16 Bits ANALOG INPUT Voltage Range VIN – VINGND 0 VREF V Operating Input Voltage VIN –0.1 +3 V VINGND –0.1 +0.5 V Analog Input CMRR fIN = 10 kHz 65 dB Input Current 500 kSPS Throughput 7.7 µA Input Impedance1 THROUGHPUT SPEED Complete Cycle 2 µs Throughput Rate 0 500 kSPS DC ACCURACY Integral Linearity Error –2.0 +2.0 LSB2 No Missing Codes 16 Bits Differential Linearity Error –1.0 +1.5 LSB Transition Noise 0.7 LSB Unipolar Zero Error, T 3 MIN to TMAX ±5 LSB Unipolar Zero Error Temperature Drift ±0.5 ppm/°C Full-Scale Error, T 3 MIN to TMAX REF = 2.5 V ±0.08 % of FSR Full-Scale Error Temperature Drift ±1.4 ppm/°C Power Supply Sensitivity AVDD = 5 V ± 5% ±2 LSB AC ACCURACY Signal-to-Noise fIN = 20 kHz 88 89.2 dB4 Spurious Free Dynamic Range fIN = 20 kHz 96 107 dB Total Harmonic Distortion fIN = 20 kHz –106 –96 dB Signal-to-(Noise + Distortion) fIN = 20 kHz 88 89.1 dB –60 dB Input, fIN = 20 kHz 30 dB –3 dB Input Bandwidth 12 MHz SAMPLING DYNAMICS Aperture Delay 2 ns Aperture Jitter 5 ps rms Transient Response Full-Scale Step 750 ns REFERENCE Internal Reference Voltage VREF @ 25°C 2.493 2.5 2.507 V Internal Reference Temperature Drift –40°C to +85°C ±3 ±15 ppm/°C Output Voltage Hysteresis –40°C to +85°C 50 ppm Long Term Drift 100 ppm/1000 Hours Line Regulation AVDD = 5 V ± 5% ±15 ppm/V Turn-On Settling Time CREF = 10 µF 5 ms Temperature Pin Voltage Output @ 25°C 300 mV Temperature Sensitivity 1 mV/°C Output Resistance 4 kΩ External Reference Voltage Range 2.3 2.5 AVDD – 1.85 V External Reference Current Drain 500 kSPS Throughput 120 µA Rev. 0 | Page 3 of 28 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS DEFINITIONS OF SPECIFICATIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT INFORMATION CONVERTER OPERATION Transfer Functions TYPICAL CONNECTION DIAGRAM Analog Input Driver Amplifier Choice Voltage Reference Input Power Supply POWER DISSIPATION VERSUS THROUGHPUT CONVERSION CONTROL DIGITAL INTERFACE PARALLEL INTERFACE SERIAL INTERFACE MASTER SERIAL INTERFACE Internal Clock SLAVE SERIAL INTERFACE External Clock External Discontinuous Clock Data Read After Conversion External Clock Data Read During Conversion MICROPROCESSOR INTERFACING SPI Interface (ADSP-219x) APPLICATION HINTS BIPOLAR AND WIDER INPUT RANGES LAYOUT EVALUATING THE AD7666’S PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
