Datasheet AD7896 (Analog Devices) - 4
Description2.7 V to 5.5 V, 12-Bit, 8 µs ADC in 8-Pin SO/DIP
Pages / Page16 / 4 — AD7896. Test Conditions/. Parameter. A Version1. B Version. J Version. S …
RevisionD
AD7896. Test Conditions/. Parameter. A Version1. B Version. J Version. S Version Unit. Comments
AD7896 Test Conditions/ Parameter A Version1 B Version J Version S Version Unit Comments
POWER REQUIREMENTS VDD 2.7/5.5 2.7/5.5 2.7/5.5 2.7/5.5 V min/max IDD 4 4 4 4 mA max Digital Input @ DGND, VDD = 2.7 V to 3.6 V 5 5 5 5 mA max Digital Inputs @ DGND, VDD = 5 V ± 10% Power Dissipation 10.8 10.8 10.8 10.8 mW max VDD = 2.7 V, Typically 9 mW Power-Down Mode Digital Inputs @ DGND IDD @ 25°C 5 5 5 typ 5 µA max VDD = 2.7 V to 3.6 V TMIN to TMAX 15 15 75 75 µA max VDD = 2.7 V to 3.6 V IDD @ 25°C 50 50 50 50 µA max VDD = 5 V ± 10% TMIN to TMAX 150 150 500 500 µA max VDD = 5 V ± 10% Power Dissipation @ 25°C 13.5 13.5 13.5 13.5 µW max VDD = 2.7 V NOTES 1Temperature ranges are as follows: A, B Versions: –40°C to +85°C; J Version: 0°C to +70°C; S Version: –55°C to +125°C. 2Applies to Mode 1 operation. See the section on Operating Modes. 3See Terminology. 4Sample tested @ 25°C to ensure compliance. 5This 14 µs includes the wake-up time from standby. This wake-up time is timed from the rising edge of CONVST, whereas conversion is timed from the falling edge of CONVST, for narrow CONVST pulsewidth the conversion time is effectively the wake-up time plus conversion time, hence 14 µs. This can be seen from Figure 3. Note that if the CONVST pulsewidth is greater than 6 µs, the effective conversion time will increase beyond 14 µs. Specifications subject to change without notice.
TIMING CHARACTERISTICS1 (VDD = 2.7 V to 5.5 V, AGND = DGND = 0 V) Parameter A, B Versions J Version S Version Unit Test Conditions/Comments
t1 40 40 40 ns min CONVST Pulsewidth t2 402 402 452 ns min SCLK High Pulsewidth t3 402 402 452 ns min SCLK Low Pulsewidth t4 Data Access Time after Falling Edge of SCLK 603 603 703 ns max VDD = 5 V ± 10% 1003 1003 1103 ns max VDD = 2.7 V to 3.6 V t5 10 10 10 ns min Data Hold Time after Falling Edge of SCLK t6 504 504 504 ns max Bus Relinquish Time after Falling Edge of SCLK NOTES 1Sample tested at 25°C to ensure compliance. All input signals are measured with tr = tf = 1 ns (10% to 90% of V DD) and timed from a voltage level of 1.4 V. 2The SCLK maximum frequency is 10 MHz. Care must be taken when interfacing to account for the data access time, t 4, and the setup time required for the user’s processor. These two times will determine the maximum SCLK frequency that the user’s system can operate with. See Serial Interface section for more information. 3Measured with the load circuit of Figure 1 and defined as the time required for an output to cross 0.8 V or 2 V. 4Derived from the measured time taken by the data outputs to change 0.5 V when loaded with the circuit of Figure 1. The measured number is then extrapolated back to remove the effects of charging or discharging the 50 pF capacitor. This means that the time, t 6, quoted in the timing characteristics is the true bus relinquish time of the part and as such is independent of external bus loading capacitances.
1.6mA TO OUTPUT 1.6V PIN 50pF 400
A
Figure 1. Load Circuit for Access Time and Bus Relinquish Time Rev. D –3– Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS TIMING CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION PIN FUNCTION DESCRIPTIONS TERMINOLOGY Relative Accuracy Differential Nonlinearity Unipolar Offset Error Positive Full-Scale Error Track-and-Hold Acquisition Time Signal-to-(Noise + Distortion) Ratio Total Harmonic Distortion Peak Harmonic or Spurious Noise Intermodulation Distortion CONVERTER DETAILS CIRCUIT DESCRIPTION Analog Input Section Track-and-Hold Section Timing and Control OPERATING MODES Mode 1 Operation (High Sampling Performance) Mode 2 Operation (Auto Sleep after Conversion) Serial Interface MICROPROCESSOR/MICROCONTROLLER INTERFACE AD7896–8051 Interface AD7896–68HC11/L11 Interface AD7896–ADSP-2103/ADSP-2105 Interface AD7896–DSP56002/L002 Interface AD7896 PERFORMANCE Linearity Noise Dynamic Performance (Mode 1 Only) Effective Number of Bits Power Considerations OUTLINE DIMENSIONS ORDERING GUIDE Revision History
