Datasheet ADL5502 (Analog Devices) - 2
Description450 MHz TO 6000 MHz Crest Factor Detector
Pages / Page30 / 2 — ADL5502* PRODUCT PAGE QUICK LINKS Last Content Update: 10/03/2017. …
ADL5502* PRODUCT PAGE QUICK LINKS Last Content Update: 10/03/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADL5502* PRODUCT PAGE QUICK LINKS Last Content Update: 10/03/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADL5502 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADL5502 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Data Sheet
View all ADL5502 EngineerZone Discussions. • ADL5502: 450 MHz to 6000 MHz Crest Factor Detector Data Sheet
SAMPLE AND BUY
Visit the product page to see pricing options.
TOOLS AND SIMULATIONS
• ADIsimPLL™
TECHNICAL SUPPORT
• ADIsimRF Submit a technical question or find your regional support • ADL5502 S-Parameters number.
REFERENCE DESIGNS DOCUMENT FEEDBACK
• CN0187 Submit feedback for this data sheet.
REFERENCE MATERIALS Product Selection Guide
• RF Source Booklet
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION RMS CIRCUIT DESCRIPTION AND FILTERING FILTERING ENVELOPE PEAK-HOLD CIRCUIT OUTPUT BUFFERS MEASURING THE CREST FACTOR APPLICATIONS INFORMATION BASIC CONNECTIONS RF INPUT INTERFACING Resistive Tap RF Input Multiple RF Inputs LINEARITY Output Swing VRMS Output Offset OUTPUT DRIVE CAPABILITY AND BUFFERING SELECTING THE SQUARE-DOMAIN FILTER AND OUTPUT LOW-PASS FILTER POWER CONSUMPTION, ENABLE, AND POWER-ON/POWER-OFF RESPONSE TIME DEVICE CALIBRATION AND ERROR CALCULATION CALIBRATION FOR IMPROVED ACCURACY CALCULATION OF CREST FACTOR (CF) DRIFT OVER A REDUCED TEMPERATURE RANGE OPERATION AT HIGH FREQUENCIES DEVICE HANDLING EVALUATION BOARD Operating in Peak-Hold Mode Land Pattern and Soldering Information OUTLINE DIMENSIONS ORDERING GUIDE
