Datasheet ADL5502 (Analog Devices) - 10
Description | 450 MHz TO 6000 MHz Crest Factor Detector |
Pages / Page | 30 / 10 — ADL5502. TYPICAL PERFORMANCE CHARACTERISTICS. 0.1. 450. 900. 1900. 2350. … |
Revision | A |
File Format / Size | PDF / 1.8 Mb |
ADL5502. TYPICAL PERFORMANCE CHARACTERISTICS. 0.1. 450. 900. 1900. 2350. 2600. 3500. 4000. 5000. 6000. 0.01. –25. –20. –15. –10. INPUT (dBm). 2.0. 1.8. 1.6. 1.4
ADL5502 TYPICAL PERFORMANCE CHARACTERISTICS
TA = 25°C, VS = 3.0 V, CFLTR = 10 nF, COUT = open, light condition ≤ 600 lux, 75 Ω input termination resistor, colors: black = +25°C, blue = −40°C, red = +85°C, unless otherwise noted.
1 1 ) ) V V ( ( T T U U TP TP 0.1 OU 0.1 450 OU 450 900 900 1900 1900 2350 2350 2600 2600 3500 3500 4000 4000 5000 5000 6000 6000 0.01 0.01 –25 –20 –15 –10 –5 0 5 10 15
7 04
0 00 1- 1- 63
INPUT (dBm)
63
INPUT (dBm)
07 07 Figure 4. VRMS Output vs. Input Level, 450 MHz, 900 MHz, 1900 MHz, Figure 7. PEAK Output vs. Input Level, 450 MHz, 900 MHz, 1900 MHz, 2350 MHz, 2600 MHz, 3500 MHz, 4000 MHz, 5000 MHz, 6000 MHz, Supply 3.0 V 2350 MHz, 2600 MHz, 3500 MHz, 4000 MHz, 5000 MHz, 6000 MHz, Supply 3.0 V
2.0 3 450 450 900 1.8 900 1900 1900 2350 2 2350 1.6 2600 2600 3500 3500 1.4 4000 4000 5000 1 5000 ) 6000 1.2 6000 V B) ( d T ( U 1.0 R 0 TP 0.8 OU RRO E –1 0.6 0.4 –2 0.2 0 –3 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0
05 0 08
1- 0 1- 63
INPUT (V rms)
63
INPUT (dBm)
07 07 Figure 5. VRMS Output vs. Input Level (Linear Scale), 450 MHz, 900 MHz, 1900 MHz, Figure 8. PEAK Linearity Error vs. Input Level, 450 MHz, 900 MHz, 1900 MHz, 2350 MHz, 2600 MHz, 3500 MHz, 4000 MHz, 5000 MHz, 6000 MHz, Supply 3.0 V 2350 MHz, 2600 MHz, 3500 MHz, 4000 MHz, 5000 MHz, 6000 MHz, Supply 3.0 V
3 450 2.5V 900 2.7V 1900 2 2350 3.0V 2600 1 3.3V 3500 4000 1 5000 ) 6000 ) B V d ( T R ( 0 U VRMS PEAK TP RRO E 0.1 OU –1 –2 –3 0.01
06
–25 –20 –15 –10 –5 0 5 10 15 –25 –20 –15 –10 –5 0 5 10 15
09 0 0 1- 1- 63
INPUT (dBm)
63
INPUT (dBm)
07 07 Figure 6. VRMS Linearity Error vs. Input Level, 450 MHz, 900 MHz, 1900 MHz, Figure 9. VRMS and PEAK Outputs vs. Input Level, 2.5 V, 2.7 V, 3.0 V, 3.3 V, and 2350 MHz, 2600 MHz, 3500 MHz, 4000 MHz, 5000 MHz, 6000 MHz, Supply 3.0 V 3.5 V Supplies, 900 MHz Frequency Rev. A | Page 8 of 28 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION RMS CIRCUIT DESCRIPTION AND FILTERING FILTERING ENVELOPE PEAK-HOLD CIRCUIT OUTPUT BUFFERS MEASURING THE CREST FACTOR APPLICATIONS INFORMATION BASIC CONNECTIONS RF INPUT INTERFACING Resistive Tap RF Input Multiple RF Inputs LINEARITY Output Swing VRMS Output Offset OUTPUT DRIVE CAPABILITY AND BUFFERING SELECTING THE SQUARE-DOMAIN FILTER AND OUTPUT LOW-PASS FILTER POWER CONSUMPTION, ENABLE, AND POWER-ON/POWER-OFF RESPONSE TIME DEVICE CALIBRATION AND ERROR CALCULATION CALIBRATION FOR IMPROVED ACCURACY CALCULATION OF CREST FACTOR (CF) DRIFT OVER A REDUCED TEMPERATURE RANGE OPERATION AT HIGH FREQUENCIES DEVICE HANDLING EVALUATION BOARD Operating in Peak-Hold Mode Land Pattern and Soldering Information OUTLINE DIMENSIONS ORDERING GUIDE
