Datasheet OP200 (Analog Devices)
DescriptionDual Low Offset, Low Power Operational Amplifier
Pages / Page11 / 1 — DLA LAND AND MARITIME. COLUMBUS, OHIO 43218-3990. STANDARD. …
File Format / SizePDF / 125 Kb
DLA LAND AND MARITIME. COLUMBUS, OHIO 43218-3990. STANDARD. http://www.landandmaritime.dla.mil. MICROCIRCUIT. DRAWING. 5962-88593
Datasheet OP200 Analog Devices
REVISIONS LTR DESCRIPTION DATE (YR-MO-DA) APPROVED A Change to one part-one part number format. Added table III. 91-12-11 M. A. FRYE B Changes in accordance with NOR 5962-R036-97. 96-11-26 R. MONNIN C Change slew rate value in table I. Remove table III, figures 2, 3, 4, and 5. 00-10-18 R. MONNIN Update boilerplate. Redrawn. -rrp D Replaced reference to MIL-STD-973 with reference to MIL-PRF-38535. -rrp 03-05-01 R. MONNIN 11-05-10 C. SAFFLE E Make change to the AVS, +VOP, and -VOP test subgroups from 4, 5, and 6 to 1, 2, and 3 as specified under table I. Make change to the En and SR test subgroups from 7 to 4 as specified under table I. Make change to TCVIO test subgroups from 8 to 2 and 3 under table I. Make change to paragraph 4.4.1 and table IIA. Update drawing to current requirements. -rrp F Update drawing to current MIL-PRF-38535 requirements. -rrp 16-10-06 C. SAFFLE THE ORIGINAL FIRST SHEET OF THIS DRAWING HAS BEEN REPLACED. REV SHEET REV SHEET REV STATUS REV F F F F F F F F F F OF SHEETS SHEET 1 2 3 4 5 6 7 8 9 10 PMIC N/A PREPARED BY GARY ZAHN
DLA LAND AND MARITIME COLUMBUS, OHIO 43218-3990 STANDARD
CHECKED BY
http://www.landandmaritime.dla.mil MICROCIRCUIT
RAY MONNIN
DRAWING
APPROVED BY THIS DRAWING IS AVAILABLE D. A. DiCENZO MICROCIRCUIT, LINEAR, LOW OFFSET, LOW FOR USE BY ALL DEPARTMENTS POWER DUAL OPERATIONAL AMPLIFIER, AND AGENCIES OF THE DRAWING APPROVAL DATE MONOLITHIC SILICON DEPARTMENT OF DEFENSE 88-07-25 REVISION LEVEL SIZE CAGE CODE AMSC N/A
5962-88593
F A
67268
SHEET 1 OF 10 DSCC FORM 2233 APR 97 5962-E543-16 Document Outline DEPARTMENT OF DEFENSE SPECIFICATION DEPARTMENT OF DEFENSE STANDARDS
