Datasheet OP200 (Analog Devices) - 3
DescriptionDual Low Offset, Low Power Operational Amplifier
Pages / Page11 / 3 — STANDARD. 5962-88593. MICROCIRCUIT DRAWING
File Format / SizePDF / 125 Kb
STANDARD 5962-88593 MICROCIRCUIT DRAWING
1.3 Absolute maximum ratings. 1/ Supply voltage range ... ±20 V dc Input voltage .. Supply voltage Output short-circuit duration .. Indefinite Differential input voltage .. ±30 V dc Storage temperature range .. -65°C to +150°C Lead temperature range (soldering, 60 seconds) .. +300°C Junction temperature (TJ) .. +150°C Thermal resistance, junction-to-case (θJC) ... See MIL-STD-1835 Thermal resistance (θJA): Case P ... 119°C/W Case 2 .. 120°C/W 1.4 Recommended operating conditions. Supply voltage (VCC) .. ±15 V dc Source resistance from ground to input terminals (RS) .. 50 Ω Ambient operating temperature range (TA) .. -55°C to +125°C 2. APPLICABLE DOCUMENTS 2.1 Government specification, standards, and handbooks. The following specification, standards, and handbooks form a part of this drawing to the extent specified herein. Unless otherwise specified, the issues of these documents are those cited in the solicitation or contract. DEPARTMENT OF DEFENSE SPECIFICATION MIL-PRF-38535 - Integrated Circuits, Manufacturing, General Specification for. DEPARTMENT OF DEFENSE STANDARDS MIL-STD-883 - Test Method Standard Microcircuits. MIL-STD-1835 - Interface Standard Electronic Component Case Outlines. DEPARTMENT OF DEFENSE HANDBOOKS MIL-HDBK-103 - List of Standard Microcircuit Drawings. MIL-HDBK-780 - Standard Microcircuit Drawings. (Copies of these documents are available online at http://quicksearch.dla.mil/ or from the Standardization Document Order Desk, 700 Robbins Avenue, Building 4D, Philadelphia, PA 19111-5094.) 2.2 Order of precedence. In the event of a conflict between the text of this drawing and the references cited herein, the text of this drawing takes precedence. Nothing in this document, however, supersedes applicable laws and regulations unless a specific exemption has been obtained. ________ 1/ Stresses above the absolute maximum rating may cause permanent damage to the device. Extended operation at the maximum levels may degrade performance and affect reliability.
STANDARD
SIZE
5962-88593 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 F 3 DSCC FORM 2234 APR 97 Document Outline DEPARTMENT OF DEFENSE SPECIFICATION DEPARTMENT OF DEFENSE STANDARDS
