Datasheet LTC6363 (Analog Devices) - 4
DescriptionPrecision, Low Power Differential Amplifier/ADC Driver Family
Pages / Page40 / 4 — Complete LTC6363 Family. The. denotes the specifications which apply
RevisionC
File Format / SizePDF / 703 Kb
Complete LTC6363 Family The denotes the specifications which apply
LTC6363 Family ELECTRICAL CHARACTERISTICS
denotes the specifications which apply over the full operating temperature range, otherwise specifications and typical values are at TA = 25°C. V+ = 10V, V– = 0V, VCM = VOCM = VICM = 5V, VSHDN = open. VS is defined as (V+ – V–). VOUTCM is defined as (V+OUT + V–OUT)/2. VICM is defined as (V+IN + V–IN)/2. VOUTDIFF is defined as (V+OUT – V–OUT). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IS Supply Current VS = 3V, Active 1.7 1.8 mA l 1.95 mA VS = 3V, Shutdown l 20 40 µA VS = 5V, Active 1.75 1.85 mA l 2 mA VS = 5V, Shutdown l 30 65 µA VS = 10V, Active 1.9 2 mA l 2.2 mA VS = 10V, Shutdown l 70 130 µA VIL SHDN Input Logic Low l (V+ + V–)/2 + 0.4 V VIH SHDN Input Logic High l (V+ + V–)/2 + 1.2 V tON Turn-On Time 4 μs tOFF Turn-Off Time 2 μs RSHDN Input Resistance, SHDN Pin l 300 500 700 kΩ
LTC6363 Only. The
denotes the specifications which apply over the full operating temperature range, otherwise specifications and typical values are at TA = 25°C. V+ = 10V, V– = 0V, VCM = VOCM = VICM = 5V, VSHDN = open. VS is defined as (V+ – V–). VOUTCM is defined as (V+OUT + V–OUT)/2. VICM is defined as (V+IN + V–IN)/2. VOUTDIFF is defined as (V+OUT – V–OUT). Typical specifications apply to the internal amplifier inside all versions. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOSDIFF (Note 7) Differential Offset Voltage VS = 3V 25 100 µV VICM =1.5V l 200 µV VS = 5V 25 100 µV VICM = 2.5V l 200 µV VS = 10V 25 100 µV VICM = 5V l 200 µV ∆VOSDIFF/∆T Differential Offset Voltage Drift VS = 3V l 0.45 1.25 µV/°C (Notes 7, 8) VS = 5V l 0.45 1.25 µV/°C VS = 10V l 0.45 1.25 µV/°C AVOL Open-Loop Voltage Gain 125 dB IB (Note 10) Input Bias Current VS = 3V l –1 –0.5 –0.1 µA VS = 5V l –1 –0.5 –0.1 µA VS = 10V l –1 –0.5 –0.1 µA IOS (Note 10) Input Offset Current VS = 3V ±5 ±50 nA l ±75 nA VS = 5V ±5 ±50 nA l ±75 nA VS = 10V ±5 ±50 nA l ±75 nA ∆IOS/∆T (Note 8) Input Offset Current Drift VS = 3V l ±30 ±150 pA/°C VS = 5V l ±30 ±150 pA/°C VS = 10V l ±30 ±150 pA/°C RIN Input Resistance Common Mode 50 MΩ Differential Mode 40 kΩ CIN Input Capacitance Differential Mode 2 pF 6363fb 4 For more information www.linear.com/LTC6363
