Datasheet LTC6416 (Analog Devices) - 2
Description2GHz Low Noise Differential 16-Bit ADC Buffer
Pages / Page20 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION …
File Format / SizePDF / 401 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION Lead Free Finish. TAPE AND REEL (MINI). TAPE AND REEL
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION Lead Free Finish TAPE AND REEL (MINI) TAPE AND REEL
LTC6416
TOP VIEW Total Supply Voltage (V+ to GND)..4V Input Current (CLLO, CLHI, V 1 10 CM, IN+, IN–) ...±10mA VCM V+ Output Current (OUT+, OUT–) ...±22.5mA CLHI 2 9 GND IN+ 3 11 8 Operating Temperature Range (Note 2).. –40°C to 85°C OUT+ IN– 4 7 OUT– Specifi ed Temperature Range (Note 3) .. –40°C to 85°C CLLO 5 6 GND Storage Temperature Range ... –65°C to 150°C Junction Temperature ... 150°C DDB PACKAGE 10-LEAD (3mm s 2mm) PLASTIC DFN TJMAX = 150°C, θJA = 76°C/W, θJC = 13.5°C/W EXPOSED PAD (PIN 11) IS GND, MUST BE SOLDERED TO PCB
ORDER INFORMATION Lead Free Finish TAPE AND REEL (MINI) TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC6416CDDB#TRMPBF LTC6416CDDB#TRPBF LDDY 10-Lead (3mm × 2mm) Plastic DFN 0°C to 70°C LTC6416IDDB#TRMPBF LTC6416IDDB#TRPBF LDDY 10-Lead (3mm × 2mm) Plastic DFN –40°C to 85°C TRM = 500 pieces. *Temperature grades are identifi ed by a label on the shipping container. Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. Consult LTC Marketing for information on lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
3.6V ELECTRICAL CHARACTERISTICS The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3.6V, GND = 0V, No RLOAD, CLOAD = 6pF. VCM = 1.25V, CLHI = V+, CLLO = 0V unless otherwise noted. VINCM is defi ned as (IN+ + IN–)/2. VOUTCM is defi ned as (OUT+ + OUT–)/2. VINDIFF is defi ned as (IN+ – IN–). VOUTDIFF is defi ned as (OUT+ – OUT–). See DC test circuit schematic. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Input/Output Characteristics
GDIFF Differential Gain VINDIFF = ±1.2V Differential –0.3 –0.15 0 dB l –0.4 0 dB TCGDIFF Differential Gain Temperature Coeffi cient l –0.00033 dB/°C VSWINGDIFF Differential Output Voltage Swing VOUTDIFF, VINDIFF = ±2.3V 3.7 4.2 VP-P l 3.3 VP-P VSWINGMIN Output Voltage Swing Low Single-Ended Measurement of OUT+, 0.2 0.3 V OUT–. VINDIFF = ±2.3V l 0.35 V VSWINGMAX Output Voltage Swing High Single-Ended Measurement of OUT+, 2.15 2.3 V OUT–. VINDIFF = ±2.3V l 2 V IOUT Output Current Drive Single-Ended Measurement of OUT+, OUT– l ±20 mA VOS Differential Input Offset Voltage IN+ = IN– = 1.25V, VOS = VOUTDIFF/ –5 –0.5 5 mV GDIFF l –10 10 mV TCVOS Differential Input Offset Voltage Drift l 1 μV/°C VIOCM Common Mode Offset Voltage, Input to VOUTCM – VINCM –65 –47 –15 mV Output l –75 –5 mV 6416f 2
