Datasheet ADA4522-1, ADA4522-2, ADA4522-4 (Analog Devices)
Description55 V, EMI Enhanced, Zero Drift, Ultralow Noise, Rail-to-Rail Output Operational Amplifiers
Pages / Page33 / 1 — 55 V, EMI Enhanced, Zero Drift, Ultralow Noise,. Rail-to-Rail Output …
RevisionF
55 V, EMI Enhanced, Zero Drift, Ultralow Noise,. Rail-to-Rail Output Operational Amplifiers. Data Sheet. ADA4522-1. /ADA4522-2
Datasheet ADA4522-1, ADA4522-2, ADA4522-4 Analog Devices, Revision: F
link to page 8
55 V, EMI Enhanced, Zero Drift, Ultralow Noise, Rail-to-Rail Output Operational Amplifiers Data Sheet ADA4522-1 /ADA4522-2 /ADA4522-4 FEATURES PIN CONNECTION DIAGRAM Low offset voltage: 5 μV maximum OUT A 1 8 V+ Extremely low offset voltage drift: 22 nV/°C maximum –IN A 2 ADA4522-2 7 OUT B Low voltage noise density: 5.8 nV/√Hz typical +IN A TOP VIEW 3 6 –IN B (Not to Scale)
001
117 nV p-p typical from 0.1 Hz to 10 Hz V– 4 5 +IN B
168- 13
Low input bias current: 50 pA typical
Figure 1. 8-Lead MSOP (RM Suffix) and 8-Lead SOIC (R Suffix)
Unity-gain crossover: 3 MHz typical
Pin Configuration
Single-supply operation: input voltage range includes
For the ADA4522-1 and ADA4522-4 pin connections and for
ground and rail-to-rail output
more information about the pin connections for these products,
Wide range of operating voltages
see the Pin Configurations and Function Descriptions section.
Single-supply operation: 4.5 V to 55 V 100 Dual-supply operation: ±2.25 V to ±27.5 V AV = 100 5V 30V Integrated EMI filters ) 55V Unity-gain stable /√Hz V n ( APPLICATIONS Y 10 IT NS Inductance, capacitance, and resistance (LCR) meter/ E D E megohmmeter front-end amplifiers IS Load cell and bridge transducers NO E 1 Magnetic force balance scales AG T L High precision shunt current sensing O V Thermocouple/resistance temperature detector (RTD) sensors Programmable logic controller (PLC) input and output 0.110 100 1k 10k 100k 1M
165
amplifiers
68-
FREQUENCY (Hz)
31 1
GENERAL DESCRIPTION
Figure 2. Voltage Noise Density vs. Frequency, VSY = ±15 V
Table 1. Zero Drift Op Amps (<0.1 μV/°C)
The ADA4522-1/ADA4522-2/ADA4522-4 are single/dual/quad
Supply Voltage 5 V 16 V 30 V 55 V
channel, zero drift op amps with low noise and power, ground Single ADA4528-1 AD8638 ADA4638-1 ADA4522-1 sensing inputs, and rail-to-rail output, optimized for total AD8628 accuracy over time, temperature, and voltage conditions. The AD8538 wide operating voltage and temperature ranges, as well as the ADA4051-1 high open-loop gain and very low dc and ac errors make the Dual ADA4528-2 AD8639 ADA4522-2 devices well suited for amplifying very small input signals and AD8629 for accurately reproducing larger signals in a wide variety of AD8539 applications. ADA4051-2 Quad AD8630 ADA4522-4 The ADA4522-1/ADA4522-2/ADA4522-4 performance is specified at 5.0 V, 30 V, and 55 V power supply voltages. These devices operate over the range of 4.5 V to 55 V, and are excellent for applications using single-ended supplies of 5 V, 10 V, 12 V, and 30 V, or for applications using higher single supplies and dual supplies of ±2.5 V, ±5 V, and ±15 V. The ADA4522-1/ ADA4522-2/ADA4522-4 use on-chip filtering to achieve high immunity to electromagnetic interference (EMI). The ADA4522-1/ADA4522-2/ADA4522-4 are fully specified over the extended industrial temperature range of −40°C to +125°C and are available in 8-lead MSOP, 8-lead SOIC, 14-lead SOIC, and 14-lead TSSOP packages.
Rev. F Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2015–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—5.0 V OPERATION ELECTRICAL CHARACTERISTICS—30 V OPERATION ELECTRICAL CHARACTERISTICS—55 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE POWER SEQUENCING ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ON-CHIP INPUT EMI FILTER AND CLAMP CIRCUIT THERMAL SHUTDOWN INPUT PROTECTION SINGLE-SUPPLY AND RAIL-TO-RAIL OUTPUT LARGE SIGNAL TRANSIENT RESPONSE Case 1 Case 2 NOISE CONSIDERATIONS 1/f Noise Source Resistance Residual Ripple Current Noise Density EMI REJECTION RATIO CAPACITIVE LOAD STABILITY APPLICATIONS INFORMATION SINGLE-SUPPLY INSTRUMENTATION AMPLIFIER LOAD CELL/STRAIN GAGE SENSOR SIGNAL CONDITIONING USING THE ADA4522-2 PRECISION LOW-SIDE CURRENT SHUNT SENSOR PRINTED CIRCUIT BOARD LAYOUT COMPARATOR OPERATION USE OF LARGE SOURCE RESISTANCE Unity Gain Follower with Large Source Resistance Workaround OUTLINE DIMENSIONS ORDERING GUIDE
