link to page 1 link to page 1 link to page 1 link to page 1 link to page 2 link to page 3 link to page 3 link to page 4 link to page 5 link to page 7 link to page 7 link to page 7 link to page 7 link to page 8 link to page 10 link to page 21 link to page 22 link to page 22 link to page 22 link to page 23 link to page 23 link to page 24 link to page 25 link to page 25 link to page 27 link to page 27 link to page 27 link to page 27 link to page 28 link to page 28 link to page 29 link to page 30 link to page 31 link to page 32 ADA4522-1/ADA4522-2/ADA4522-4Data SheetTABLE OF CONTENTS Features .. 1 Input Protection ... 22 Applications ... 1 Single-Supply and Rail-to-Rail Output ... 23 General Description ... 1 Large Signal Transient Response .. 23 Pin Connection Diagram .. 1 Noise Considerations ... 24 Revision History ... 2 EMI Rejection Ratio .. 25 Specifications ... 3 Capacitive Load Stability ... 25 Electrical Characteristics—5.0 V Operation .. 3 Applications Information .. 27 Electrical Characteristics—30 V Operation ... 4 Single-Supply Instrumentation Amplifier .. 27 Electrical Characteristics—55 V Operation ... 5 Load Cell/Strain Gage Sensor Signal Conditioning Using the Absolute Maximum Ratings .. 7 ADA4522-2 .. 27 Thermal Resistance .. 7 Precision Low-Side Current Shunt Sensor.. 28 Power Sequencing .. 7 Printed Circuit Board Layout ... 28 ESD Caution .. 7 Comparator Operation .. 29 Pin Configurations and Function Descriptions ... 8 Use of Large Source Resistance .. 30 Typical Performance Characteristics ... 10 Outline Dimensions ... 31 Theory of Operation .. 21 Ordering Guide .. 32 On-Chip Input EMI Filter and Clamp Circuit ... 22 Thermal Shutdown ... 22 REVISION HISTORY9/2017—Rev. E to Rev. F1/2016—Rev. A to Rev. B Added Power Sequencing Section .. 7 Updated Outline Dimensions ... 29 Added Use of Large Source Resistance Section .. 30
Added Figure 89 and Table 11; Renumbered Sequentially ... 30 10/2015—Rev. 0 to Rev. A Added ADA4522-4 ... Universal 10/2016—Rev. D to Rev. E Changes to General Description Section ... 1 Changes to Figure 73 .. 23 Change to Common-Mode Rejection Ratio Parameter, Table 2 ... 3
Change to Offset Voltage Drift Parameter, Table 3 ... 4 4/2016—Rev. C to Rev. D Change to Offset Voltage Drift Parameter and Input Offset Changed ADA4522-4 Pin 4 to V+ .. Throughout Current Parameter, Table 4 .. 5 Changed ADA4522-4 Pin 11 to V− .. Throughout Changes to Table 6 ... 7 Changes to Figure 5 and Table 9 ... 9 Added Figure 4 and Table 8; Renumbered Sequentially .. 8 Changes to Figure 34 .. 13 2/2016—Rev. B to Rev. C Changes to Figure 67 .. 19 Added ADA4522-1 ... Universal Changes to Applications Information Section ... 20 Changes to Common-Mode Rejection Ratio Parameter and Changes to Thermal Shutdown Section .. 21 Supply Current per Amplifier Parameter, Table 2 .. 3 Changes to Single-Supply Instrumentation Amplifier Section ... 25 Changes to Offset Voltage Drift Parameter, and Supply Current Changes to Precision Low-Side Current Shunt Sensor Section .. 27 per Amplifier Parameter, Table 3 .. 4 Changes to Printed Circuit Board Layout Section .. 28 Changes to Offset Voltage Drift Parameter, Input Offset Current Added Figure 89 and Figure 90; Outline Dimensions ... 30 Parameter, and Supply Current per Amplifier Parameter, Changes to Ordering Guide .. 30 Table 4 .. 5 Added Figure 3 and Table 7; Renumbered Sequentially ... 8 5/2015—Revision 0: Initial Version Moved Theory of Operation Section ... 21
Changes to Figure 71 .. 21
Changes to Figure 72 .. 22
Changes to Ordering Guide .. 32
Rev. F | Page 2 of 33 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—5.0 V OPERATION ELECTRICAL CHARACTERISTICS—30 V OPERATION ELECTRICAL CHARACTERISTICS—55 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE POWER SEQUENCING ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ON-CHIP INPUT EMI FILTER AND CLAMP CIRCUIT THERMAL SHUTDOWN INPUT PROTECTION SINGLE-SUPPLY AND RAIL-TO-RAIL OUTPUT LARGE SIGNAL TRANSIENT RESPONSE Case 1 Case 2 NOISE CONSIDERATIONS 1/f Noise Source Resistance Residual Ripple Current Noise Density EMI REJECTION RATIO CAPACITIVE LOAD STABILITY APPLICATIONS INFORMATION SINGLE-SUPPLY INSTRUMENTATION AMPLIFIER LOAD CELL/STRAIN GAGE SENSOR SIGNAL CONDITIONING USING THE ADA4522-2 PRECISION LOW-SIDE CURRENT SHUNT SENSOR PRINTED CIRCUIT BOARD LAYOUT COMPARATOR OPERATION USE OF LARGE SOURCE RESISTANCE Unity Gain Follower with Large Source Resistance Workaround OUTLINE DIMENSIONS ORDERING GUIDE
