Datasheet MOC3061M, MOC3062M, MOC3063M, MOC3162M, MOC3163M (ON Semiconductor)
ManufacturerON Semiconductor
Description6-Pin DIP Zero-Cross Triac Driver Optocoupler (600 Volt Peak)
Pages / Page12 / 1 — DATA SHEET. www.onsemi.com. PDIP6 8.51x6.35, 2.54P. CASE 646BX. CASE …
File Format / SizePDF / 276 Kb
DATA SHEET. www.onsemi.com. PDIP6 8.51x6.35, 2.54P. CASE 646BX. CASE 646BY. CASE 646BZ. Description. MARKING DIAGRAM. Features. SCHEMATIC
Datasheet MOC3061M, MOC3062M, MOC3063M, MOC3162M, MOC3163M ON Semiconductor
link to page 8
DATA SHEET www.onsemi.com
(600 Volt Peak) 6
CASE 646BX
1 MOC3061M, MOC3062M,
6 MOC3063M, MOC3162M,
CASE 646BY
1 MOC3163M
6
CASE 646BZ Description
1 The MOC306XM and MOC316XM devices consist of a GaAs infrared emitting diode optically coupled to a monolithic silicon detector performing the function of a zero voltage crossing bilateral triac driver.
MARKING DIAGRAM
They are designed for use with a triac in the interface of logic systems to equipment powered from 115/240 VAC lines, such as ON solid−state relays, industrial controls, motors, solenoids and consumer MOC3061 appliances, etc. V XYYQ
Features
MOC3061 = Device Number • Simplifies Logic Control of 115/240 VAC Power V = DIN EN/IEC60747−5−5 Option (only • appears on component ordered with Zero Voltage Crossing to Minimize Conducted and Radiated Line this option) Noise X = One−Digit Year Code, e.g., ‘5’ • 600 V Peak Blocking Voltage YY = Two−Digit Work Week, Ranging from • ‘01’ to ‘53’ Superior Static dv/dt Q = Assembly Package Code ♦ 600 V/ms (MOC306xM) ♦ 1000 V/ms (MOC316xM) • Safety and Regulatory Approvals ♦ UL1577, 4,170 VACRMS for 1 Minute
SCHEMATIC
♦ DIN EN/IEC60747−5−5 • These are Pb−Free Devices
Applications
ANODE 1 6 MAIN TERM. • Solenoid/Valve Controls • Static Power Switches • CATHODE 2 5 NC* Temperature Controls • AC Motor Starters • ZERO Lighting Controls N/C 3 CROSSING 4 MAIN TERM. • AC Motor Drives CIRCUIT • E.M. Contactors • Solid State Relays *DO NOT CONNECT (TRIAC SUBSTRATE)
ORDERING INFORMATION
See detailed ordering and shipping information on page 8 of this data sheet. © Semiconductor Components Industries, LLC, 2005
1
Publication Order Number:
September, 2022 − Rev. 3 MOC3163M/D
