Datasheet MOC3061M, MOC3062M, MOC3063M, MOC3162M, MOC3163M (ON Semiconductor) - 2
ManufacturerON Semiconductor
Description6-Pin DIP Zero-Cross Triac Driver Optocoupler (600 Volt Peak)
Pages / Page12 / 2 — MOC3061M, MOC3062M, MOC3063M, MOC3162M, MOC3163M. SAFETY AND INSULATION …
File Format / SizePDF / 276 Kb
MOC3061M, MOC3062M, MOC3063M, MOC3162M, MOC3163M. SAFETY AND INSULATION RATINGS. Parameter. Characteristics. Symbol. Value. Unit
MOC3061M, MOC3062M, MOC3063M, MOC3162M, MOC3163M SAFETY AND INSULATION RATINGS Parameter Characteristics Symbol Value Unit
(As per DIN EN/IEC 60747−5−5, this optocoupler is suitable for “safe electrical insulation” only within the safety limit data. Compliance with the safety ratings shall be ensured by means of protective circuits.)
Installation Classifications per DIN VDE 0110/1.89 Table 1, For Rated Mains Voltage <150 VRMS I–IV <300 VRMS I–IV Climatic Classification 40/85/21 Pollution Degree (DIN VDE 0110/1.89) 2 Comparative Tracking Index 175
Symbol Parameter Value Unit
VPR Input−to−Output Test Voltage, Method A, VIORM x 1.6 = VPR, 1360 Vpeak Type and Sample Test with tm = 10 s, Partial Discharge < 5 pC Input−to−Output Test Voltage, Method B, VIORM x 1.875 = VPR, 1594 Vpeak 100% Production Test with tm = 1 s, Partial Discharge < 5 pC VIORM Maximum Working Insulation Voltage 850 Vpeak VIOTM Highest Allowable Over−Voltage 6000 Vpeak External Creepage ≥7 mm External Clearance ≥7 mm External Clearance (for Option TV, 0.4” Lead Spacing) ≥10 mm DTI Distance Through Insulation (Insulation Thickness) ≥0.5 mm RIO Insulation Resistance at TS, VIO = 500 V >109 W
ABSOLUTE MAXIMUM RATINGS
(TA = 25°C unless otherwise noted)
Symbol Parameter Device Value Unit TOTAL DEVICE
TSTG Storage Temperature All −40 to +125 °C TOPR Operating Temperature All −40 to +85 °C TJ Junction Temperature Range All −40 to +100 °C TSOL Lead Solder Temperature All 260 for °C 10 seconds PD Total Device Power Dissipation at 25°C Ambient All 250 mW Derate Above 25°C 2.94 mW/°C
EMITTER
IF Continuous Forward Current All 60 mA VR Reverse Voltage All 6 V PD Total Power Dissipation at 25°C Ambient All 120 mW Derate Above 25°C 1.41 mW/°C
DETECTOR
VDRM Off−State Output Terminal Voltage All 600 V ITSM Peak Non−Repetitive Surge Current (Single Cycle 60 Hz Sine Wave) All 1 Apeak ITM Peak Repetitive On−State Current All 100 mApeak PD Total Power Dissipation at 25°C Ambient All 150 mW Derate Above 25°C 1.76 mW/°C Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are exceeded, device functionality should not be assumed, damage may occur and reliability may be affected.
www.onsemi.com 2
