Datasheet 1N5400-1N5408 (PanJit) - 2
ManufacturerPanJit
DescriptionHigh Current Plastic Silicon Rectifier. Voltage 50 to 1000 Volt Current 3 Ampere
Pages / Page4 / 2 — 1N5400~1N5408. RATING AND CHARACTERISTIC CURVES 4. SINGLE PHASE HALF WAVE …
File Format / SizePDF / 101 Kb
1N5400~1N5408. RATING AND CHARACTERISTIC CURVES 4. SINGLE PHASE HALF WAVE 60Hz. RESISTIVE OR INDUCTIVE LOAD
1N5400~1N5408 RATING AND CHARACTERISTIC CURVES 4 SINGLE PHASE HALF WAVE 60Hz RESISTIVE OR INDUCTIVE LOAD
1N5400~1N5408
3
2
.375" (9.5mm) LEAD LENGTH 1
0 0 20 40 60 80 100 120 140 160 240 PEAK FORWARD SURGE CURRENT,
AMPERES AVERAGEFORWARDRECITIFIED
CURRENTAMPERES 5 200 160 120 80 40 0
1 AMBIENT TEMPERAURE, OC
Fig.1-FORWARD CURRENT DERATING CURVE INSTANTANEOUS REVERSE CURRENT , m A 10 100 NO. OF CYCLE AT 60HZ Fig.2-MAXIMUM NON -REPETITIVE SURGE CURRENT 1000 INSTANTANEOUS FORWARD CURRENT
AMPERES 100 o 100 TJ = 125 C 10 TJ = 100 OC 1.0
O TJ = 25 C 0.1 10 1.0 0.1 0 .01 20 40 60 80 100 120 140 PERCENTAGE OF PEAK REVERSE VOLTAGE,% Fig.3-TYPICALREVERSECHARACTERISTIC 0.5 0.7 0.9 1.1 1.3 1.5 1.7 INSTANTANEOUS FORWARD VOLTAGE, VOLTS Fig.4-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTIC CAPACITANCE, pF 100 10 1 .1 1 10 100 REVERSE VOLTAGE, VOLTS Fig.5-TYPICAL JUNCTION CAPACITANCE August 7,2015-REV.03 PAGE . 2
