Datasheet ADA4610-1, ADA4610-2, ADA4610-4 (Analog Devices) - 4
DescriptionLow Noise, Precision, Rail-to-Rail Output, JFET Single Op Amp
Pages / Page25 / 4 — ADA4610-1/ADA4610-2/ADA4610-4. Data Sheet. Parameter. Symbol. Test …
RevisionI
File Format / SizePDF / 761 Kb
ADA4610-1/ADA4610-2/ADA4610-4. Data Sheet. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit. ELECTRICAL CHARACTERISTICS
ADA4610-1/ADA4610-2/ADA4610-4 Data Sheet Parameter Symbol Test Conditions/Comments Min Typ Max Unit ELECTRICAL CHARACTERISTICS
link to page 5 link to page 5 link to page 5
DYNAMIC PERFORMANCE Slew Rate ±SR RL = 2 kΩ, AV = +1 Rising 151 21 V/µs Falling 151 46 V/µs Gain Bandwidth Product GBP VIN = 5 mV p-p, RL = 2 kΩ, AV = +100 15.4 MHz Unity-Gain Crossover UGC VIN = 5 mV p-p, RL = 2 kΩ,AV = +1 9.3 MHz Phase Margin φM 61 Degrees −3 dB Closed-Loop Bandwidth −3 dB AV = +1, VIN = 5 mV p-p 10.6 MHz Total Harmonic Distortion (THD) + Noise THD + N 1 kHz, AV = +1, RL = 2 kΩ, VIN = 1 V rms 0.00025 % NOISE PERFORMANCE Voltage Noise en p-p 0.1 Hz to 10 Hz 0.45 µV p-p Voltage Noise Density en f = 10 Hz 14 nV/√Hz f = 100 Hz 8.20 nV/√Hz f = 1 kHz 7.30 nV/√Hz f = 10 kHz 7.30 nV/√Hz 1 Guaranteed by design and characterization.
VSY = ±15 V, VCM = 0 V, TA = 25°C, unless otherwise noted.
Table 3. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS B Grade (ADA4610-1/ADA4610-2) 0.2 0.4 mV −40°C < TA < +125°C 0.8 mV A Grade 0.4 1 mV −40°C < TA < +125°C 1.8 mV Offset Voltage Drift ΔVOS/ΔT B Grade (ADA4610-1/ADA4610-2)1 0.5 4 µV/°C A Grade1 (SOIC, MSOP, LFSCP) 1 8 µV/°C A Grade1 (SOT-23) 1 12 µV/°C Input Bias Current IB 5 25 pA −40°C < TA < +125°C 1.50 nA Input Offset Current IOS 2 20 pA −40°C < TA < +125°C 0.25 nA Input Voltage Range −12.5 +12.5 V Common-Mode Rejection Ratio CMRR VCM = −12.5 V to +12.5 V 100 115 dB −40°C < TA < +125°C 96 dB Large Signal Voltage Gain AVO RL = 2 kΩ, VOUT = ±13.5 V ADA4610-2 104 107 dB −40°C < TA < +125°C 91 dB ADA4610-1/ADA4610-4 102 104 dB −40°C < TA < +125°C 86 dB Input Capacitance VCM = 0 V Differential 3.1 pF Common-Mode 4.8 pF Input Resistance VCM = 0 V >1013 Ω Rev. G | Page 4 of 25 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS COMPARATIVE VOLTAGE AND VARIABLE VOLTAGE GRAPHS FUNCTIONAL DESCRIPTION APPLICATIONS INFORMATION INPUT OVERVOLTAGE PROTECTION PEAK DETECTOR CURRENT TO VOLTAGE (I TO V) CONVERSION APPLICATIONS Photodiode Circuits COMPARATOR OPERATION OUTLINE DIMENSIONS ORDERING GUIDE
