Datasheet ADA4610-1, ADA4610-2, ADA4610-4 (Analog Devices) - 5
DescriptionLow Noise, Precision, Rail-to-Rail Output, JFET Single Op Amp
Pages / Page25 / 5 — Data Sheet. ADA4610-1/ADA4610-2/ADA4610-4. Parameter. Symbol. Test …
RevisionI
File Format / SizePDF / 761 Kb
Data Sheet. ADA4610-1/ADA4610-2/ADA4610-4. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet ADA4610-1/ADA4610-2/ADA4610-4 Parameter Symbol Test Conditions/Comments Min Typ Max Unit
OUTPUT CHARACTERISTICS Output Voltage High VOH RL = 2 kΩ 14.80 14.90 V −40°C < TA < +125°C 14.65 V RL = 600 Ω 14.25 14.47 V −40°C < TA < +125°C 13.35 V Output Voltage Low VOL RL = 2 kΩ −14.90 −14.85 V −40°C < TA < +125°C −14.75 V RL = 600 Ω −14.68 −14.60 V −40°C < TA < +125°C −14.30 V Short-Circuit Current ISC ±79 mA POWER SUPPLY Power Supply Rejection Ratio PSRR VSY = ±4.5 V to ±18 V ADA4610-2 106 125 dB −40°C < TA < +125°C 103 dB ADA4610-1/ADA4610-4 104 117 dB −40°C < TA < +125°C 100 dB Supply Current per Amplifier ISY IOUT = 0 mA 1.60 1.85 mA −40°C < TA < +125°C 2.0 mA DYNAMIC PERFORMANCE Slew Rate ±SR RL = 2 kΩ, AV = +1 Rising 171 25 V/µs Falling 171 61 V/µs Gain Bandwidth Product GBP VIN = 5 mV p-p, RL = 2 kΩ, AV = +100 16.3 MHz Unity-Gain Crossover UGC VIN = 5 mV p-p, RL = 2 kΩ, AV = +1 9.3 MHz Phase Margin φM 66 Degrees −3 dB Closed-Loop Bandwidth −3 dB AV = +1, VIN = 5 mV p-p 9.5 MHz Total Harmonic Distortion (THD) + Noise THD + N 1 kHz, AV = +1, RL = 2 kΩ, VIN = 5 V rms 0.00025 % NOISE PERFORMANCE Peak-to-Peak Voltage Noise en p-p 0.1 Hz to 10 Hz bandwidth 0.45 µV p-p Voltage Noise Density en f = 10 Hz 14 nV/√Hz f = 100 Hz 8.50 nV/√Hz f = 1 kHz 7.30 nV/√Hz f = 10 kHz 7.30 nV/√Hz 1 Guaranteed by design and characterization. Rev. G | Page 5 of 25 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS COMPARATIVE VOLTAGE AND VARIABLE VOLTAGE GRAPHS FUNCTIONAL DESCRIPTION APPLICATIONS INFORMATION INPUT OVERVOLTAGE PROTECTION PEAK DETECTOR CURRENT TO VOLTAGE (I TO V) CONVERSION APPLICATIONS Photodiode Circuits COMPARATOR OPERATION OUTLINE DIMENSIONS ORDERING GUIDE
