Datasheet AD712 (Analog Devices) - 7
DescriptionPrecision, Low Cost, High Speed, BiFET Dual Op Amp
Pages / Page21 / 7 — ) 15. m (. E S. RRE. G A 10. RL = 2kΩ. 25°C. IE U. SUPPLY VOLTAGE ± V. …
RevisionI
File Format / SizePDF / 408 Kb
) 15. m (. E S. RRE. G A 10. RL = 2kΩ. 25°C. IE U. SUPPLY VOLTAGE ± V. 106. s) p. 107. G IN. OUT. 108. –VOUT. T 10. 109. VO T. URRE. 1010. BI T U 1011 INP. 1012. –60
) 15 m ( E S RRE G A 10 RL = 2kΩ 25°C IE U SUPPLY VOLTAGE ± V 106 s) p 107 G IN OUT 108 –VOUT T 10 109 VO T URRE 1010 BI T U 1011 INP 1012 –60
AD712 TYPICAL PERFORMANCE CHARACTERISTICS
20 6 ) 15 A) (V 5 G m ( IN T W N E S RRE G A 10 4 T CU L RL = 2kΩ NT VO 25°C CE T S PU IE U IN 5 3 Q 0
5 02
2 0 5 10 15 20
0
0 5 10 15 20
00 3- 3-
SUPPLY VOLTAGE ± V
82
SUPPLY VOLTAGE ± V
82 00 00 Figure 2. Input Voltage Swing vs. Supply Voltage Figure 5. Quiescent Current vs. Supply Voltage
20 106 s) p ) 107 m (V A 15 ( G IN +V 0) OUT W = 108 –VOUT CM E S V G ( A T T 10 N 109 L RL = 2kΩ VO T 25°C URRE U C P 1010 T AS U 5 O BI T U 1011 INP 0
03
1012 0 5 10 15 20
0 06 3-
–60 –40 –20 0 20 40 60 80 100 120 140
0 3-
SUPPLY VOLTAGE ± V
82 00
TEMPERATURE (°C)
082 0 Figure 3. Output Voltage Swing vs. Supply Voltage Figure 6. Input Bias Current vs. Temperature
30 100 ) 25 -p p V ) 10 ( (Ω 20 ING W S ±15V SUPPLIES E DANCE E 15 P 1.0 AG T M L I O UT V 10 P UT UT P O 0.1 UT O 5 0 0.01
7 04
10 100 1k 10k
0
1k 10k 100k 1M 10M
-00 3- 23
LOAD RESISTANCE (Ω)
082
FREQUENCY (Hz)
08 0 0 Figure 4. Output Voltage Swing vs. Load Resistance Figure 7. Output Impedance vs. Frequency Rev. H | Page 6 of 20 Document Outline FEATURES GENERAL DESCRIPTION CONNECTION DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS SETTLING TIME OPTIMIZING SETTLING TIME OP AMP SETTLING TIME—A MATHEMATICAL MODEL APPLICATIONS INFORMATION GUARDING DAC CONVERTER APPLICATIONS NOISE CHARACTERISTICS DRIVING THE ANALOG INPUT OF AN ADC DRIVING A LARGE CAPACITIVE LOAD FILTERS ACTIVE FILTER APPLICATIONS SECOND-ORDER LOW-PASS FILTER 9-POLE CHEBYCHEV FILTER OUTLINE DIMENSIONS ORDERING GUIDE
