21 /10 — AD795. 2.0. RL = 10kΩ. A) m (. 1.5. p- 20. V ( E G A. CURRE. L 1.0. O V. …
Revision
C
PDF / 334 Kb
AD795. 2.0. RL = 10kΩ. A) m (. 1.5. p- 20. V ( E G A. CURRE. L 1.0. O V. U 10. NT CE. S 0.5. UI Q. 10k. 100k. FREQUENCY (Hz). SUPPLY VOLTAGE (±V). 1000
AD795302.0RL = 10kΩ25A) m (p)1.5NTp- 20V ( E G ACURRETY15LL 1.0PO VUPTSU 10TPNT CEOUS 0.5E5UI Q0 2 0 25 1k10k100k1M 02 05101520 0 5- 5- FREQUENCY (Hz) 84 SUPPLY VOLTAGE (±V) 84 00 00 Figure 22. Large Signal Frequency Response Figure 25. Quiescent Supply Current vs. Supply Voltage 100050SAMPLE SIZE = 1419) Ω (40100DANCESETP IMUNI F 30UTOP10EUTAGO PNT 20O O LRCE ED-1PE S10O CL0.10 6 1k10k100k1M10M 2305- –500 –400 –300 –200 –1000100200300400500 024- FREQUENCY (Hz) 84 82 00 INPUT OFFSET VOLTAGE (µV) 00 Figure 23. Closed-Loop Output Impedance vs. Frequency Figure 26. Typical Distribution of Input Offset Voltage –60VIN = 3V rms RL = 10kΩ–70–8010kΩB) d–90+VSHD (0.1µFT–10010kΩ7V2IN6VOUTAD795–1103RCLL410kΩ100pF0.1µF–120 4 7 1001k10k100k 02 02 5- 5- FREQUENCY (Hz) 84 –V 84 S 00 00 Figure 24. Total Harmonic Distortion vs. Frequency Figure 27. Unity Gain Inverter Rev. C | Page 9 of 20 Document Outline Features Applications Connection Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Minimizing Input Current Circuit Board Notes Offset Nulling AC Response with High Value Source and Feedback Resistance Overload Issues Input Protection Preamplifier Applications Minimizing Noise Contributions Using a T Network A pH Probe Buffer Amplifier Outline Dimensions Ordering Guide
