Datasheet LTC6433-15 (Analog Devices) - 7
DescriptionLow Frequency to 1.4GHz 50Ω Gain Block IF Amplifier
Pages / Page16 / 7 — Typical perForMance characTerisTics. A-Grade
Typical perForMance characTerisTics A-Grade
LTC6433-15
Typical perForMance characTerisTics A-Grade TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD = 50Ω, unless otherwise noted. Measurements are performed using Test Circuit A, measuring from 50Ω SMA to 50Ω SMA without de-embedding (Note 4). OIP3 vs RF Output Power Over OIP3 vs Frequency Frequency OIP3 vs Voltage Over Frequency
55 55 55 VCC = 5V, T = 25°C POUT = 2dBm/TONE 50 50 fSPACE = 1MHz 50 ZIN = ZOUT = 50Ω 45 45 45 40 40 35 35 OIP3 (dBm) 40 OIP3 (dBm) 30 OIP3 (dBm) 100kHz 30 100kHz 1MHz 25 1MHz 25 35 10MHz 10MHz 100MHz 100MHz 20 400MHz 20 400MHz 1GHz 1GHz 30 15 15 0.1 1 10 100 1000 5000 –10 –8 –6 –4 –2 0 2 4 6 8 10 4 4.25 4.50 4.75 5 5.25 5.50 5.75 6 FREQUENCY (MHz) RF POWER OUT (dBm/TONE) VOLTAGE (V) 643315 G08 643315 G09 643315 G10 VCC = 5V, T = 25°C VCC = 5V, T = 25°C POUT = 2dBm/TONE POUT = 2dBm/TONE fSPACE = 1MHz fSPACE = 1MHz ZIN = ZOUT = 50Ω ZIN = ZOUT = 50Ω
OIP3 vs Tone Spacing OIP3 vs Frequency Over Over Frequency Case Temperature
55 55 50 50 45 45 40 40 35 35 OIP3 (dBm) 30 OIP3 (dBm) 100kHz 30 TCASE = 100°C 1MHz T 25 CASE = 85°C 10MHz 25 TCASE = 25°C 100MHz VCC = 5V, T = 25°C T V 20 CASE = 0°C CC = 5V 400MHz P 20 OUT = 2dBm/TONE TCASE = –20°C POUT = 2dBm/TONE 1GHz ZIN = ZOUT = 50Ω T ZIN = ZOUT = 50Ω 15 CASE = –40°C 15 0.001 0.01 0.1 1 10 70 0.1 1.0 10 100 1000 TONE SPACING (MHz) FREQUENCY (MHz) 643315 G11 643315 G12 643315f For more information www.linear.com/LTC6433-15 7 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information DC Electrical Characteristics AC Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit A Operation Applications Information S Parameters Package Description Related Parts Features Applications Typical Application Description Absolute Maximum Ratings Order Information DC Electrical Characteristics Pin Configuration AC Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit A Operation S Parameters Package Description Typical Application Related Parts
