Datasheet LT1715 (Analog Devices)
Description4ns, 150MHz Dual Comparator with Independent Input/Output Supplies
Pages / Page20 / 1 — FEATURES. DESCRIPTION. UltraFast: 4ns at 20mV Overdriven. 150MHz Toggle …
File Format / SizePDF / 255 Kb
FEATURES. DESCRIPTION. UltraFast: 4ns at 20mV Overdriven. 150MHz Toggle Frequency. Separate Input and Output Power Supplies
Datasheet LT1715 Analog Devices
LT1715 4ns, 150MHz Dual Comparator with Independent Input/Output Supplies
FEATURES DESCRIPTION
n
The LT®1715 is an UltraFast™ dual comparator optimized for n
low voltage operation. Separate supplies allow independent n
analog input ranges and output logic levels with no loss of n
Low Power: 4.6mA per Comparator at 3V
performance. The input voltage range extends from 100mV n Pinout Optimized for High Speed Use below VEE to 1.2V below VCC. Internal hysteresis makes the n Output Optimized for 3V and 5V Supplies LT1715 easy to use even with slow moving input signals. n TTL/CMOS Compatible Rail-to-Rail Output The rail-to-rail outputs directly interface toTTL and CMOS. n Input Voltage Range Extends 100mV The symmetric output drive results in similar rise and fall Below Negative Rail times that can be harnessed for analog applications or for n Internal Hysteresis with Specifi ed Limits easy translation to other single supply logic levels. n Specifi ed for –40°C to 125°C Temperature Range The LT1715 is available in the 10-pin MSOP package. The n Available in the 10-pin MSOP Package pinout of the LT1715 minimizes parasitic effects by placing the most sensitive inputs away from the outputs, shielded
by the power rails. n For a dual/quad single supply comparator with simi- High Speed Differential Line Receivers n lar propagation delay, see the LT1720/LT1721. For a Level Translators n single comparator with similar propagation delay, see Window Comparators n the LT1719. Crystal Oscillator Circuits n L, LT, LTC and LTM are registered trademarks of Linear Technology Corporation. Threshold Detectors/Discriminators UltraFast is a trademark of Linear Technology Corporation. n High Speed Sampling Circuits n Delay Lines
TYPICAL APPLICATION 100MHz Dual Differential Line Receiver Line Receiver Response to 100MHz Clock, 50MHz Data Both with 25mVP-P Inputs
5V 3V 3V + CLOCK OUT 1V/DIV IN A OUT A – 0V 3V + 1V/DIV DATA OUT IN B OUT B 0V – 5ns/DIV FET PROBES 1715 TA02 1715 TA01 –5V 1715fa 1
