Datasheet LT6700, LT6700HV (Analog Devices) - 2
Description | Micropower, Low Voltage, Dual Comparator with 400mV Reference |
Pages / Page | 20 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION |
File Format / Size | PDF / 461 Kb |
LT6700/LT6700HV
Total Supply Voltage (VS to GND) ..18.5V Specified Temperature Range (Note 5) Input Voltage (+IN, –IN) LT6700CS6/LT6700HVCS6/ LT6700 (Note 3) .. 18.5V to (GND – 0.3V) LT6700CDCB-1/-2/-3 .. 0°C to 70°C LT6700HV (Note 3) .. 40V to (GND – 0.3V) LT6700IS6/LT6700HVIS6/ LT6700 Output Voltage (OUT) ... 18.5V to (GND – 0.3V) LT6700IDCB-1/-2/-3 .. –40°C to 85°C LT6700HV Output Voltage (OUT) ... 40V to (GND – 0.3V) LT6700HS6/LT6700HVHS6/ Output Short-Circuit Duration (Note 2) .. Indefinite LT6700HDCB-1/-2/-3 ... –40°C to 125°C Input Current (Note 3) ..–10mA LT6700MPDCB/ Operating Temperature Range (Note 4) LT6700PMS6-1/-2/-3 ... –55°C to 125°C LT6700CS6/LT6700HVCS6/ Maximum Junction Temperature LT6700CDCB-1/-2/-3 ...–40°C to 85°C S6 Package ... 150°C LT6700IS6/LT6700HVIS6/ DCB6 Package .. 150°C LT6700IDCB-1/-2/-3 .. –40°C to 85°C Storage Temperature Range LT6700HS6/LT6700HVHS6/ S6 Package .. –65°C to 150°C LT6700HDCB-1/-2/-3 .. –40°C to 125°C DCB6 Package ... –65°C to 150°C LT6700MPDCB/ Lead Temperature, TSOT-23 (Soldering, 10 sec) ... 300°C LT6700MPS6-1/-2/-3 ... –55°C to 125°C
PIN CONFIGURATION
LT6700-1 LT6700-2 LT6700-3 LT6700HV-1 LT6700HV-2 LT6700HV-3 TOP VIEW TOP VIEW TOP VIEW OUTA 1 6 OUTB OUTA 1 6 OUTB OUTA 1 6 OUTB GND 2 5 VS GND 2 5 VS GND 2 5 VS +INA 3 4 –INB –INA 3 4 –INB +INA 3 4 +INB S6 PACKAGE S6 PACKAGE S6 PACKAGE 6-LEAD PLASTIC TSOT-23 6-LEAD PLASTIC TSOT-23 6-LEAD PLASTIC TSOT-23 TJMAX = 150°C, θJA = 230°C/W TJMAX = 150°C, θJA = 230°C/W TJMAX = 150°C, θJA = 230°C/W LT6700-1 LT6700-2 LT6700-3 TOP VIEW TOP VIEW TOP VIEW OUTA 1 6 + INA OUTA 1 6 – INA OUTA 1 6 + INA OUTB 7 2 5 GND OUTB 7 2 5 GND OUTB 7 2 5 GND VS 3 4 –INB VS 3 4 –INB VS 3 4 +INB DCB6 PACKAGE DCB6 PACKAGE DCB6 PACKAGE 6-LEAD (2mm × 3mm) PLASTIC DFN 6-LEAD (2mm × 3mm) PLASTIC DFN 6-LEAD (2mm × 3mm) PLASTIC DFN TJMAX = 125°C, θJA = 64°C/W TJMAX = 125°C, θJA = 64°C/W TJMAX = 125°C, θJA = 64°C/W SOLDERED EXPOSED PAD (PIN 7) SOLDERED EXPOSED PAD (PIN 7) SOLDERED EXPOSED PAD (PIN 7) INTERNALLY CONNECTED TO GND INTERNALLY CONNECTED TO GND INTERNALLY CONNECTED TO GND (PCB CONNECTION OPTIONAL) (PCB CONNECTION OPTIONAL) (PCB CONNECTION OPTIONAL) 6700123fh 2 For more information www.linear.com/LT6700 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Pin Functions Typical Performance Characteristics Applications Information Package Information Revision History Typical Applications Related Parts
