Datasheet MCP6421, MCP6422, MCP6424 (Microchip) - 5
ManufacturerMicrochip
DescriptionThe Microchip’s MCP6421/2/4 operational amplifiers (op amps) has low input bias current (1 pA, typical) and rail-to-rail input and output operation
Pages / Page46 / 5 — MCP6421/2/4. TABLE 1-3:. TEMPERATURE SPECIFICATIONS. Electrical …
File Format / SizePDF / 3.9 Mb
MCP6421/2/4. TABLE 1-3:. TEMPERATURE SPECIFICATIONS. Electrical Characteristics:. Parameters. Sym. Min. Typ. Max. Units. Conditions
MCP6421/2/4 TABLE 1-3: TEMPERATURE SPECIFICATIONS Electrical Characteristics: Parameters Sym Min Typ Max Units Conditions
link to page 5 link to page 5 link to page 5
Unless otherwise indicated, VDD = +1.8V to +5.5V and VSS = GND.
Parameters Sym. Min. Typ. Max. Units Conditions Temperature Ranges
Operating Temperature Range TA -40 — +125 °C
Note 1
Storage Temperature Range TA -65 — +150 °C
Thermal Package Resistances
Thermal Resistance, 5L-SC70 JA — 331 — °C/W Thermal Resistance, 5L-SOT-23 JA — 221 — °C/W Thermal Resistance, 8L-MSOP JA — 211 — °C/W Thermal Resistance, 8L-SOIC JA — 150 — °C/W Thermal Resistance, 14L-SOIC JA — 95 — °C/W Thermal Resistance, 14L-TSSOP JA — 100 — °C/W
Note 1:
The internal junction temperature (TJ) must not exceed the absolute maximum specification of +150°C.
1.3 Test Circuits
The circuit used for most DC and AC tests is shown in CF 6.8 pF Figure 1-1. This circuit can independently set VCM and VOUT (see Equation 1-1). Note that VCM is not the circuit’s Common mode voltage ((V RG RF P + VM)/2), and that V 100 k 100 k OST includes VOS plus the effects (on the input offset V V error, V P DD/2 OST) of the temperature, CMRR, PSRR and V A DD OL. VIN+ C C
EQUATION 1-1:
B1 B2
MCP6421
100 nF 1 µF G = R  R DM F G V V = V + V  2  2 IN– C M P DD V = V – V V V OST IN – IN+ M OUT R R C V = V  2 + V – V  + V 1 + G  G RF L L OUT DD P M OST DM 100 k 100 k 100 k 30 pF Where: GDM = Differential Mode Gain (V/V) CF 6.8 pF V V L CM = Op Amp’s Common Mode (V) Input Voltage
FIGURE 1-1:
AC and DC Test Circuit for VOST = Op Amp’s Total Input Offset Voltage (mV) Most Specifications.  2013 Microchip Technology Inc. DS20005165B-page 5 Document Outline Typical Application Package Types 1.0 Electrical Characteristics 1.1 Absolute Maximum Ratings † 1.2 Specifications TABLE 1-1: DC electrical specifications TABLE 1-2: AC Electrical Specifications TABLE 1-3: Temperature Specifications 1.3 Test Circuits FIGURE 1-1: AC and DC Test Circuit for Most Specifications. 2.0 Typical Performance Curves FIGURE 2-1: Input Offset Voltage. FIGURE 2-2: Input Offset Voltage Drift. FIGURE 2-3: Input Offset Voltage vs. Common Mode Input Voltage. FIGURE 2-4: Input Offset Voltage vs. Common Mode Input Voltage. FIGURE 2-5: Input Offset Voltage vs. Output Voltage. FIGURE 2-6: Input Offset Voltage vs. Power Supply Voltage. FIGURE 2-7: Input Noise Voltage Density vs. Common Mode Input Voltage. FIGURE 2-8: Input Noise Voltage Density vs. Frequency. FIGURE 2-9: CMRR, PSRR vs. Frequency. FIGURE 2-10: CMRR, PSRR vs. Ambient Temperature. FIGURE 2-11: Input Bias, Offset Current vs. Ambient Temperature. FIGURE 2-12: Input Bias Current vs. Common Mode Input Voltage. FIGURE 2-13: Quiescent Current vs. Ambient Temperature. FIGURE 2-14: Quiescent Current vs. Power Supply Voltage. FIGURE 2-15: Quiescent Current vs. Common Mode Input Voltage. FIGURE 2-16: Quiescent Current vs. Common Mode Input Voltage. FIGURE 2-17: Open-Loop Gain, Phase vs. Frequency. FIGURE 2-18: DC Open-Loop Gain vs. Ambient Temperature. FIGURE 2-19: DC Open-Loop Gain vs. Output Voltage Headroom. FIGURE 2-20: Gain Bandwidth Product, Phase Margin vs. Ambient Temperature. FIGURE 2-21: Gain Bandwidth Product, Phase Margin vs. Ambient Temperature. FIGURE 2-22: Output Short Circuit Current vs. Power Supply Voltage. FIGURE 2-23: Output Voltage Swing vs. Frequency. FIGURE 2-24: Output Voltage Headroom vs. Output Current. FIGURE 2-25: Output Voltage Headroom vs. Output Current. FIGURE 2-26: Output Voltage Headroom vs. Ambient Temperature. FIGURE 2-27: Output Voltage Headroom vs. Ambient Temperature. FIGURE 2-28: Slew Rate vs. Ambient Temperature. FIGURE 2-29: Small Signal Non-Inverting Pulse Response. FIGURE 2-30: Small Signal Inverting Pulse Response. FIGURE 2-31: Large Signal Non-Inverting Pulse Response. FIGURE 2-32: Large Signal Inverting Pulse Response. FIGURE 2-33: The MCP6421/2/4 Device Shows No Phase Reversal. FIGURE 2-34: Closed Loop Output Impedance vs. Frequency. FIGURE 2-35: Measured Input Current vs. Input Voltage (below VSS). FIGURE 2-36: EMIRR vs. Frequency. FIGURE 2-37: EMIRR vs. RF Input Peak- to-Peak Voltage. FIGURE 2-38: Channel-to-Channel Separation vs. Frequency. 3.0 Pin Descriptions TABLE 3-1: Pin Function Table 3.1 Analog Outputs 3.2 Analog Inputs 3.3 Power Supply Pins (VSS, VDD) 4.0 Application Information 4.1 Rail-to-Rail Input FIGURE 4-1: Simplified Analog Input ESD Structures. FIGURE 4-2: Protecting the Analog Inputs. FIGURE 4-3: Protecting the Analog Inputs. 4.2 Rail-to-Rail Output 4.3 Capacitive Loads FIGURE 4-4: Output Resistor, RISO Stabilizes Large Capacitive Loads. FIGURE 4-5: Recommended RISO Values for Capacitive Loads. 4.4 Supply Bypass 4.5 Unused Op Amps FIGURE 4-6: Unused Op Amps. 4.6 PCB Surface Leakage FIGURE 4-7: Example Guard Ring Layout for Inverting Gain. 4.7 Electromagnetic Interference Rejection Ratio (EMIRR) Definitions 4.8 Application Circuits FIGURE 4-8: CO Gas Sensor Circuit. FIGURE 4-9: Pressure Sensor Amplifier. FIGURE 4-10: Battery Current Sensing. 5.0 Design Aids 5.1 SPICE Macro Model 5.2 FilterLab® Software 5.3 Microchip Advanced Part Selector (MAPS) 5.4 Analog Demonstration and Evaluation Boards 5.5 Application Notes 6.0 Packaging Information 6.1 Package Marking Information Appendix A: Revision History Product Identification System Trademarks Worldwide Sales and Service
