Datasheet ADA4077-1, ADA4077-2, ADA4077-4 (Analog Devices) - 8
Description | 4 MHz, 7 nV/√Hz, Low Offset and Drift, High Precision Single Amplifier |
Pages / Page | 27 / 8 — ADA4077-1/ADA4077-2/ADA4077-4. Data Sheet. PIN CONFIGURATIONS AND … |
Revision | E |
File Format / Size | PDF / 987 Kb |
ADA4077-1/ADA4077-2/ADA4077-4. Data Sheet. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. NIC. –IN. ADA4077-1 7 V+. +IN. TOP VIEW. OUT
ADA4077-1/ADA4077-2/ADA4077-4 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS NIC 1 8 NIC NIC 1 8 NIC –IN 2 ADA4077-1 7 V+ –IN 2 ADA4077-1 7 V+ +IN 3 TOP VIEW 6 OUT +IN 3 6 TOP VIEW OUT V– (Not to Scale) (Not to Scale) 4 5 NIC V– 4 5 NIC
205 105
NIC = NOT INTERNALLY CONNECTED.
10238-
10238- Figure 5. ADA4077-1 Pin Configuration, 8-Lead MSOP (RM-8) Figure 6. ADA4077-1 Pin Configuration, 8-Lead SOIC (R-8)
Table 6. ADA4077-1 P in Function Descriptions, 8-Lead MSOP and 8-Lead SOIC Pin No. Mnemonic Description
1, 5, 8 NIC Not internally connected. 2 −IN Inverting Input. 3 +IN Noninverting Input. 4 V− Negative Supply Voltage. 6 OUT Output. 7 V+ Positive Supply Voltage. Rev. E | Page 8 of 27 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONNECTION DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS, ±5 V ELECTRICAL CHARACTERISTICS, ±15 V ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUIT THEORY OF OPERATION APPLICATIONS INFORMATION OUTPUT PHASE REVERSAL LOW POWER LINEARIZED RTD PROPER BOARD LAYOUT LONG-TERM DRIFT TEMPERATURE HYSTERESIS OUTLINE DIMENSIONS ORDERING GUIDE
