Datasheet ADA4001-2 (Analog Devices) - 9 Manufacturer Analog Devices Description Low Noise, Low Input Bias Current, Rail-to-Rail Output, JFET Dual Op Amp Pages / Page 13 / 9 — ADA4001-2. Data Sheet. –40. VSY = ±15V. –60. TA = 25°C. RL = 2kΩ. AV = … Revision C File Format / Size PDF / 372 Kb Document Language English
ADA4001-2. Data Sheet. –40. VSY = ±15V. –60. TA = 25°C. RL = 2kΩ. AV = +1. N (. –80. L = 100pF. ARAT. S (V). –100. S L. –120. –10. CHANNE. –140. OUTPUT. –15
Text Version of Document ADA4001-2 Data Sheet –40 20 ADA4001-2 ADA4001-2 VSY = ±15V 15 VSY = ±15V –60 TA = 25°C TA = 25°C RL = 2kΩ AV = +1 B) 10 d RL = 2kΩ N ( C –80 L = 100pF IO 5 ARAT S (V) –100 P 0 T E L S L VO –5 –120 –10 CHANNE –140 OUTPUT –15 INPUT –160 –20 0.01 0.1 1 10 100 0310 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 026FREQUENCY (kHz) TIME (ms) 10375- 10375- Figure 20. Channel Separation Figure 23. No Phase Reversal1 12 ADA4001-2 VSY = ±15V 10 ADA4001-2 FIN = 1kHz V 8 SY = ±15V 0.1 TA = 25°C TA = 25°C RL = 2kΩ 6 AV = +1 RL = 2kΩ 4 CL = 100pF 0.01 %) 2 N ( S (V) T 0 L HD + 0.001 –2 T VO –4 –6 0.0001 –8 –10 0.00001 –12 0.001 0.01 0.1 1 10 0240 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 032AMPLITUDE (V rms) TIME (µs) 10375- 10375- Figure 21. THD + N vs. Amplitude Figure 24. Positive Slew Rate0.01 12 ADA4001-2 V ADA4001-2 SY = ±15V 10 T V A = 25°C SY = ±15V R 8 T L = 2kΩ A = 25°C A 6 V = +1 RL = 2kΩ 0.001 4 CL = 100pF %) 2 N ( S (V) T 0 500kHz FILTER L HD + –2 T VO 0.0001 80kHz FILTER –4 –6 –8 –10 0.00001 –12 0.01 0.1 1 10 100 0250 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 033FREQUENCY (kHz) TIME (µs) 10375- 10375- Figure 22. THD + N vs. Frequency Figure 25. Negative Slew Rate Rev. C | Page 8 of 12 Document Outline Features Applications Pin Configuration General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Total Noise Including Source Resistors I-V Conversion Applications Photodiode Circuits Input Bias Current Noise Considerations Outline Dimensions Ordering Guide
