Datasheet ADA4855-3 (Analog Devices) - 7
Description | Single Supply, High Speed, Rail-to-Rail Output, Triple Op Amp |
Pages / Page | 21 / 7 — ADA4855-3. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. IN1. … |
Revision | A |
File Format / Size | PDF / 596 Kb |
ADA4855-3. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. IN1. NC 1. 12 +VS. +IN2 2. 11 OUT2. NC 3. 10 –IN2. PD 4. +VS. IN3. NOTES
ADA4855-3 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS T1 S IN1 N1 + –I OU –V 16 15 14 13 NC 1 12 +VS +IN2 2 11 OUT2 ADA4855-3 NC 3 10 –IN2 PD 4 9 +VS 5 6 7 8 S IN3 N3 T3 + –I –V OU NOTES
003
1. NC = NO CONNECT. 2. EXPOSED PAD CONNECTED TO –VS.
07685- Figure 4. Pin Configuration
Table 5. Pin Function Descriptions Pin No. Mnemonic Description
1 NC No Connect. 2 +IN2 Noninverting Input 2. 3 NC No Connect. 4 PD Power Down. 5 +IN3 Noninverting Input 3. 6 −IN3 Inverting Input 3. 7 OUT3 Output 3. 8 −VS Negative Supply. 9 +VS Positive Supply. 10 −IN2 Inverting Input 2. 11 OUT2 Output 2. 12 +VS Positive Supply. 13 −VS Negative Supply. 14 OUT1 Output 1. 15 −IN1 Inverting Input 1. 16 +IN1 Noninverting Input 1. 17 (EPAD) Exposed Pad (EPAD) The exposed pad must be connected to −VS. Rev. A | Page 6 of 20 Document Outline Features Applications Connection Diagram General Description Revision History Specifications 5 V Operation 3.3 V Operation Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Theory of Operation Applications Information Gain Configurations 20 MHz Active Low-Pass Filter RGB Video Driver Driving Multiple Video Loads PD (Power-Down) Pin Single-Supply Operation Power Supply Bypassing Layout Outline Dimensions Ordering Guide
