Datasheet AD8610, AD8620 (Analog Devices) - 8
DescriptionLow Input Bias Current, Wide BW JFET Precision Dual Op Amp
Pages / Page24 / 8 — AD8610/AD8620. 12.05. VS = ±13V. RL = 1kΩ. RL = 2kΩ. CL = 20pF. ) 12.00. …
RevisionF
File Format / SizePDF / 374 Kb
AD8610/AD8620. 12.05. VS = ±13V. RL = 1kΩ. RL = 2kΩ. CL = 20pF. ) 12.00. ) B. G = +100. H (. E 11.95. G = +10. T L. OOP. V 11.90. UT P. G = +1. L C
AD8610/AD8620 12.05 VS = ±13V RL = 1kΩ RL = 2kΩ CL = 20pF ) 12.00 ) B G = +100 H ( E 11.95 G = +10 T L OOP V 11.90 UT P G = +1 L C
AD8610/AD8620 12.05 60 VS = ±13V VS = ±13V RL = 1kΩ RL = 2kΩ CL = 20pF ) 12.00 40 V ) B G = +100 H ( d G ( HI IN E 11.95 20 GA AG G = +10 T L OOP O -L V 11.90 D 0 E UT P G = +1 OS UT L C O 11.85 –20
15 18 0 0 0- 0- 73 73
11.80
02
–40
02
–40 25 85 125 1k 10k 100k 1M 10M 100M TEMPERATURE (°C) FREQUENCY (Hz)
Figure 15. Output Voltage High vs. Temperature Figure 18. Closed-Loop Gain vs. Frequency
–11.80 260 VS = ±13V R VS = ±13V L = 1kΩ 240 VO = ±10V RL = 1kΩ ) –11.85 V ( 220 W O L ) 200 E –11.90 V AG /m T V L 180 ( O VO V –11.95 A 160 UT P UT O 140 –12.00
6
120
19 01 0 0- 0- 73 73
–12.05
02
100
02
–40 25 85 125 –40 25 85 125 TEMPERATURE (°C) TEMPERATURE (°C)
Figure 16. Output Voltage Low vs. Temperature Figure 19. AVO vs. Temperature
120 190 VS = ±5V ) 180 V S 100 O = ±3V E RL = 1kΩ RE 170 G 80 160 ND DE ) 60 V A 150 B /m d V ( ( E 140 40 VO AS A H AD8610 130 20 VS = ±13V CL = 20pF 120 N AND P AI 0 G 110
20 0 0- 73
–20 100
02
1kHz 10kHz 100kHz 1MHz 10MHz 50MHz
170
–40 25 85 125
0-
FREQUENCY
73
TEMPERATURE (°C)
02 Figure 17. Open-Loop Gain and Phase vs. Frequency Figure 20. AVO vs. Temperature Rev. F | Page 8 of 24 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION FUNCTIONAL DESCRIPTION Power Consumption Driving Large Capacitive Loads Slew Rate (Unity Gain Inverting vs. Noninverting) Input Overvoltage Protection No Phase Reversal THD Readings vs. Common-Mode Voltage Noise vs. Common-Mode Voltage Settling Time Output Current Capability Operating with Supplies Greater than ±13 V Input Offset Voltage Adjustment Programmable Gain Amplifier (PGA) High Speed Instrumentation Amplifier High Speed Filters Second-Order, Low-Pass Filter High Speed, Low Noise Differential Driver OUTLINE DIMENSIONS ORDERING GUIDE
