Datasheet AD8610, AD8620 (Analog Devices) - 9
Description | Low Input Bias Current, Wide BW JFET Precision Dual Op Amp |
Pages / Page | 24 / 9 — AD8610/AD8620. 160. 140. VS = ±13V. 120. 100. +PSRR. B) d. –PSRR. RR (. S … |
Revision | F |
File Format / Size | PDF / 374 Kb |
AD8610/AD8620. 160. 140. VS = ±13V. 120. 100. +PSRR. B) d. –PSRR. RR (. S P. –20. –40. 10k. 100k. 10M. 60M. FREQUENCY (Hz). VS = ±5V. VIN = –300mV p-p
AD8610/AD8620 160 140 VS = ±13V VS = ±13V 140 120 120 100 100 +PSRR 80 B) d B) 80 –PSRR d 60 RR ( RR ( S P 60 40 CM 20 40 0 20
1
–20
24 02 0 0- 0- 73 73
–40
02
0
02
100 1k 10k 100k 1M 10M 60M 10 100 1k 10k 100k 1M 10M 60M FREQUENCY (Hz) FREQUENCY (Hz)
Figure 21. PSRR vs. Frequency Figure 24. CMRR vs. Frequency
160 VS = ±5V VS = ±13V 140 VIN = –300mV p-p AV = –100 R 120 L = 10kΩ 100 IV) +PSRR D V/ 80 B) d ( –PSRR 300m 60 0V RR E ( S V G IN P 40 A T L 20 VO CH VOUT 2 = 5V/DIV 0
2
–20
25 02 0 0-
0V
0- 73 73
–40
02 02
100 1k 10k 100k 1M 10M 60M FREQUENCY (Hz) TIME (4µs/DIV)
Figure 22. PSRR vs. Frequency Figure 25. Positive Overvoltage Recovery
122 VS = ±13V VIN = 300mV p-p AV = –100 121 RL = 10kΩ CL = 0pF ) V 120 /DI V B) d VIN 119 300m ( 0V RR ( S E 0V P G A T 118 L O VOUT V 117 CH
23
2 = 5V/DIV
6 0 02 0- 0- 73
116
273 0 02
–40 25 85 125 TEMPERATURE (°C) TIME (4µs/DIV)
Figure 23. PSRR vs. Temperature Figure 26. Negative Overvoltage Recovery Rev. F | Page 9 of 24 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION FUNCTIONAL DESCRIPTION Power Consumption Driving Large Capacitive Loads Slew Rate (Unity Gain Inverting vs. Noninverting) Input Overvoltage Protection No Phase Reversal THD Readings vs. Common-Mode Voltage Noise vs. Common-Mode Voltage Settling Time Output Current Capability Operating with Supplies Greater than ±13 V Input Offset Voltage Adjustment Programmable Gain Amplifier (PGA) High Speed Instrumentation Amplifier High Speed Filters Second-Order, Low-Pass Filter High Speed, Low Noise Differential Driver OUTLINE DIMENSIONS ORDERING GUIDE
