Datasheet OP193, OP293 (Analog Devices) - 6
DescriptionPrecision, Micropower Operational Amplifiers
Pages / Page20 / 6 — OP193/OP293. Data Sheet. Table 3. E Grade. F Grade. Parameter. Symbol. …
RevisionD
File Format / SizePDF / 411 Kb
OP193/OP293. Data Sheet. Table 3. E Grade. F Grade. Parameter. Symbol. Conditions. Min Typ Max Min Typ Max Unit
OP193/OP293 Data Sheet Table 3 E Grade F Grade Parameter Symbol Conditions Min Typ Max Min Typ Max Unit
VS = 3.0 V, VCM = 0.1 V, TA = 25°C, unless otherwise noted.
Table 3. E Grade F Grade Parameter Symbol Conditions Min Typ Max Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS OP193 150 μV OP193, −40°C ≤ TA ≤ +125°C 250 μV OP293 100 250 μV OP293, −40°C ≤ TA ≤ +125°C 200 350 μV Input Bias Current IB −40°C ≤ TA ≤ +125°C 15 20 nA Input Offset Current IOS −40°C ≤ TA ≤ +125°C 2 4 nA Input Voltage Range VCM 0 2 0 2 V Common-Mode Rejection CMRR 0.1 ≤ VCM ≤ 2 V 97 116 94 116 dB 0.1 ≤ VCM ≤ 2 V, 90 87 dB −40°C ≤ TA ≤ +125°C Large Signal Voltage Gain AVO RL = 100 kΩ, 0.03 V ≤ VOUT ≤ 2 V 100 100 V/mV −40°C ≤ TA ≤ +85°C 75 75 V/mV −40°C ≤ TA ≤ +125°C 100 100 V/mV Long-Term Offset Voltage1 VOS 150 300 μV Offset Voltage Drift2 ΔVOS/ΔT 0.2 1.25 μV/°C OUTPUT CHARACTERISTICS Output Voltage Swing High VOH IL = 1 mA 2.1 2.14 2.1 2.14 V IL = 1 mA, –40°C ≤ TA ≤ +125°C 1.9 1.9 V IL = 5 mA 1.9 2.1 1.9 2.1 V Output Voltage Swing Low VOL IL = −1 mA 280 400 280 400 mV IL = −1 mA, −40°C ≤ TA ≤ +125°C 500 500 mV IL = −5 mA 700 900 700 900 mV Short-Circuit Current ISC ±8 ±8 mA POWER SUPPLY Power Supply Rejection Ratio PSRR VS = +1.7 V to +6 V 100 97 dB −40°C ≤ TA ≤ +125°C 94 90 dB Supply Current per Amplifier ISY VCM = 1.5 V, RL = ∞ 14.5 22 14.5 22 μA −40°C ≤ TA ≤ +125°C 22 22 μA Supply Voltage Range VS +2 ±18 +2 ±18 V NOISE PERFORMANCE Voltage Noise Density en f = 1 kHz 65 65 nV/√Hz Current Noise Density in f = 1 kHz 0.05 0.05 pA/√Hz Voltage Noise en p-p 0.1 Hz to 10 Hz 3 3 μV p-p DYNAMIC PERFORMANCE Slew Rate SR RL = 2 kΩ 10 10 V/ms Gain Bandwidth Product GBP 25 25 kHz Channel Separation VOUT = 10 V p-p, RL = 2 kΩ, 120 120 dB f = 1 kHz 1 Long-term offset voltage is guaranteed by a 1000 hour life test performed on three independent lots at 125 °C, with an LTPD of 1.3. 2 Offset voltage drift is the average of the –40°C to +25°C delta and the +25°C to +125°C delta. Rev. D | Page 6 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS FUNCTIONAL DESCRIPTION DRIVING CAPACITIVE LOADS INPUT OVERVOLTAGE PROTECTION OUTPUT PHASE REVERSAL—OP193 OUTPUT PHASE REVERSAL—OP293 BATTERY-POWERED APPLICATIONS A MICROPOWER FALSE-GROUND GENERATOR A BATTERY-POWERED VOLTAGE REFERENCE A SINGLE-SUPPLY CURRENT MONITOR A SINGLE-SUPPLY INSTRUMENTATION AMPLIFIER A LOW POWER, TEMPERATURE TO 4 mA TO 20 mA TRANSMITTER A MICROPOWER VOLTAGE CONTROLLED OSCILLATOR OUTLINE DIMENSIONS ORDERING GUIDE
