Datasheet OP193, OP293 (Analog Devices) - 7
DescriptionPrecision, Micropower Operational Amplifiers
Pages / Page20 / 7 — Data Sheet. OP193/OP293. Table 4. E Grade. F Grade. Parameter. Symbol. …
RevisionD
File Format / SizePDF / 411 Kb
Data Sheet. OP193/OP293. Table 4. E Grade. F Grade. Parameter. Symbol. Conditions. Min. Typ. Max. Unit
Data Sheet OP193/OP293 Table 4 E Grade F Grade Parameter Symbol Conditions Min Typ Max Unit
VS = 2.0 V, VCM = 0.1 V, TA = 25°C, unless otherwise noted.
Table 4. E Grade F Grade Parameter Symbol Conditions Min Typ Max Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS OP193 150 μV OP193, −40°C ≤ TA ≤ +125°C 250 μV OP293 100 250 μV OP293, −40°C ≤ TA ≤ +125°C 175 350 μV Input Bias Current IB −40°C ≤ TA ≤ +125°C 15 20 nA Input Offset Current IOS −40°C ≤ TA ≤ +125°C 2 4 nA Input Voltage Range VCM 0 1 0 1 V Large Signal Voltage Gain AVO RL = 100 kΩ, 0.03 V ≤ VOUT ≤ 1 V 60 60 V/mV −40°C ≤ TA ≤ +125°C 70 70 V/mV Long-Term Offset Voltage VOS 150 300 μV POWER SUPPLY Power Supply Rejection Ratio PSRR VS = 1.7 V to 6 V 100 97 dB −40°C ≤ TA ≤ +125°C 94 90 dB Supply Current/Amplifier ISY VCM = 1.0 V, RL = ∞ 13.2 20 13.2 20 μA −40°C ≤ TA ≤ +125°C 25 25 μA Supply Voltage Range VS +2 ±18 +2 ±18 V NOISE PERFORMANCE Voltage Noise Density en f = 1 kHz 65 65 nV/√Hz Current Noise Density in f = 1 kHz 0.05 0.05 pA/√Hz Voltage Noise en p-p 0.1 Hz to 10 Hz 3 3 μV p-p DYNAMIC PERFORMANCE Slew Rate SR RL = 2 kΩ 10 25 V/ms Gain Bandwidth Product GBP 25 kHz Rev. D | Page 7 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS FUNCTIONAL DESCRIPTION DRIVING CAPACITIVE LOADS INPUT OVERVOLTAGE PROTECTION OUTPUT PHASE REVERSAL—OP193 OUTPUT PHASE REVERSAL—OP293 BATTERY-POWERED APPLICATIONS A MICROPOWER FALSE-GROUND GENERATOR A BATTERY-POWERED VOLTAGE REFERENCE A SINGLE-SUPPLY CURRENT MONITOR A SINGLE-SUPPLY INSTRUMENTATION AMPLIFIER A LOW POWER, TEMPERATURE TO 4 mA TO 20 mA TRANSMITTER A MICROPOWER VOLTAGE CONTROLLED OSCILLATOR OUTLINE DIMENSIONS ORDERING GUIDE
