Datasheet OP193, OP293 (Analog Devices) - 9
DescriptionPrecision, Micropower Operational Amplifiers
Pages / Page20 / 9 — Data Sheet. OP193/OP293. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 150. …
RevisionD
File Format / SizePDF / 411 Kb
Data Sheet. OP193/OP293. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 150. VS = ±15V. TA = 25°C. –40°C ≤ TA ≤ +125°C. 160. 120. R O. NUM. –75. –60
Data Sheet OP193/OP293 TYPICAL PERFORMANCE CHARACTERISTICS 200 150 VS = ±15V TA = 25°C –40°C ≤ TA ≤ +125°C 160 120 R O NUM –75 –60
Data Sheet OP193/OP293 TYPICAL PERFORMANCE CHARACTERISTICS 200 150 VS = ±15V VS = ±15V TA = 25°C –40°C ≤ TA ≤ +125°C 160 120 RS RS IE IE IF IF L 120 L P 90 P AM AM F F R O 80 R O 60 BE BE NUM NUM 40 30 0 0 –75 –60 –45 –30 –15 0 15 30 45 60 75
003
0 0.2 0.4 0.6 0.8 1.0
006
OFFSET (µV) TCV
00295-
OS (µV/°C)
00295- Figure 3. Offset Distribution, VS = ±15 V Figure 6. TCVOS Distribution, VS = ±15 V
200 1 VS = 3V VS = 5V VCM = 0.1V TA = 25°C 160 0 RS A) –40°C n IE ( IF L NT 120 P –1 AM F CURRE R O 80 AS –2 +125°C BE BI UT NUM INP 40 –3 +25°C 0 –4 –75 –60 –45 –30 –15 0 15 30 45 60 75
004
0 1 2 3 4 5
007
OFFSET (µV)
00295-
COMMON-MODE VOLTAGE (V)
00295- Figure 4. Offset Distribution, VS = +3 V Figure 7. Input Bias Current vs. Common-Mode Voltage
150 120 VS = 3V 5V ≤ VS ≤ 30V VCM = 0.1V T –40°C ≤ T A = 25°C A ≤ +125°C 100 120 –PSRR RS IE IF 80 L 90 P B) d AM F 60 +PSRR RR ( R O S 60 P BE 40 NUM 30 20 0 0 0 0.2 0.4 0.6 0.8 1.0
005
10 100 1k 10k
008
TCVOS (µV/°C) FREQUENCY (Hz)
00295- 00295- Figure 5. TCVOS Distribution, VS = +3 V Figure 8. PSRR vs. Frequency Rev. D | Page 9 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS FUNCTIONAL DESCRIPTION DRIVING CAPACITIVE LOADS INPUT OVERVOLTAGE PROTECTION OUTPUT PHASE REVERSAL—OP193 OUTPUT PHASE REVERSAL—OP293 BATTERY-POWERED APPLICATIONS A MICROPOWER FALSE-GROUND GENERATOR A BATTERY-POWERED VOLTAGE REFERENCE A SINGLE-SUPPLY CURRENT MONITOR A SINGLE-SUPPLY INSTRUMENTATION AMPLIFIER A LOW POWER, TEMPERATURE TO 4 mA TO 20 mA TRANSMITTER A MICROPOWER VOLTAGE CONTROLLED OSCILLATOR OUTLINE DIMENSIONS ORDERING GUIDE
