Datasheet OP193, OP293 (Analog Devices) - 8
DescriptionPrecision, Micropower Operational Amplifiers
Pages / Page20 / 8 — OP193/OP293. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 5. Parameter. …
RevisionD
File Format / SizePDF / 411 Kb
OP193/OP293. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 5. Parameter. Rating. THERMAL RESISTANCE. Table 6. Thermal Resistance
OP193/OP293 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 5 Parameter Rating THERMAL RESISTANCE Table 6 Thermal Resistance
OP193/OP293 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 5.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these Supply Voltage1 ±18 V or any other conditions above those indicated in the operational Input Voltage1 ±18 V section of this specification is not implied. Operation beyond Differential Input Voltage1 ±18 V the maximum operating conditions for extended periods may Output Short-Circuit Duration to GND Indefinite affect product reliability. Storage Temperature Range −65°C to +150°C Operating Temperature Range −40°C to +125°C
THERMAL RESISTANCE
Junction Temperature Range −65°C to +150°C θJA is specified for the worst-case conditions, that is, a device Lead Temperature (Soldering, 60 sec) 300°C soldered in a circuit board for surface-mount packages. 1 For supply voltages less than ±18 V, the input voltage is limited to the
supply voltage.
Package Type θ 1 JA θJC Unit
8-Lead SOIC_N (S) 158 43 °C/W 1 θJA is specified for the worst-case conditions. θJA is specified for a device soldered in a circuit board for the SOIC package.
ESD CAUTION
Rev. D | Page 8 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS FUNCTIONAL DESCRIPTION DRIVING CAPACITIVE LOADS INPUT OVERVOLTAGE PROTECTION OUTPUT PHASE REVERSAL—OP193 OUTPUT PHASE REVERSAL—OP293 BATTERY-POWERED APPLICATIONS A MICROPOWER FALSE-GROUND GENERATOR A BATTERY-POWERED VOLTAGE REFERENCE A SINGLE-SUPPLY CURRENT MONITOR A SINGLE-SUPPLY INSTRUMENTATION AMPLIFIER A LOW POWER, TEMPERATURE TO 4 mA TO 20 mA TRANSMITTER A MICROPOWER VOLTAGE CONTROLLED OSCILLATOR OUTLINE DIMENSIONS ORDERING GUIDE
