Datasheet OP292, OP492 (Analog Devices) - 10
Description | Dual/Quad Single-Supply Operational Amplifiers |
Pages / Page | 20 / 10 — OP292/OP492. Data Sheet. TA = 25°C V+ = 5V. TA = 25°C. V– = 0V. VS = … |
Revision | D |
File Format / Size | PDF / 345 Kb |
OP292/OP492. Data Sheet. TA = 25°C V+ = 5V. TA = 25°C. V– = 0V. VS = ±15V. -LOOP. LOS. –10. 10k. 100k. 10M. FREQUENCY (Hz). 120. V+ = 5V. 100. N (
OP292/OP492 Data Sheet 50 50 TA = 25°C V+ = 5V TA = 25°C 40 40 V– = 0V VS = ±15V ) ) dB dB ( 30 ( 30 IN IN GA GA 20 20 -LOOP -LOOP D D E E 10 10 LOS LOS C C 0 0 –10 –10 1k 10k 100k 1M 10M
021
1k 10k 100k 1M 10M
024
FREQUENCY (Hz) FREQUENCY (Hz)
00310- 00310- Figure 21. OP292/OP492 Closed-Loop Gain vs. Frequency @ 5 V Figure 24. OP292/OP492 Closed-Loop Gain vs. Frequency @ ±15 V
120 120 TA = 25°C TA = 25°C V+ = 5V 100 100 VS = ±15V B) V– = 0V B) d d N ( N ( IO 80 IO 80 CT CT JE JE RE 60 RE 60 DE DE O O M M N- 40 N- 40 O O M M M M CO 20 CO 20 0 0 100 1k 10k 100k 1M
022
100 1k 10k 100k 1M
025
00310- 00310- Figure 22. OP292/OP492 CMR vs. Frequency @ 5 V Figure 25. OP292/OP492 CMR vs. Frequency @ ±15 V
120 120 T T ) A = 25°C A = 25°C 100 ) 100 B VS = 5V B VS = ±15V (d (d N N IO IO T 80 T 80 EC EC EJ EJ +PSSR 60 Y R 60 Y R PPL PPL –PSSR SU 40 SU 40 ER ER W W PO 20 PO 20 0 0 100 1k 10k 100k 1M
023
100 1k 10k 100k 1M
026
00310- 00310- Figure 23. OP292/OP492 PSR vs. Frequency @ 5 V Figure 26. OP292/OP492 PSR vs. Frequency @ ±15 V Rev. D | Page 10 of 20 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION PHASE REVERSAL POWER SUPPLY CONSIDERATIONS TYPICAL APPLICATIONS DIRECT ACCESS ARRANGEMENT FOR TELEPHONE LINE INTERFACE SINGLE-SUPPLY INSTRUMENTATION AMPLIFIER DAC OUTPUT AMPLIFIER 50 Hz/60 Hz SINGLE-SUPPLY NOTCH FILTER FOUR-POLE BESSEL LOW-PASS FILTER LOW COST, LINEARIZED THERMISTOR AMPLIFIER SINGLE-SUPPLY ULTRASONIC CLAMPING/LIMITING RECEIVER AMPLIFIER PRECISION SINGLE-SUPPLY VOLTAGE COMPARATOR PROGRAMMABLE PRECISION WINDOW COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
