Datasheet AD841 (Analog Devices) - 2
DescriptionWideband, Unity-Gain Stable, Fast Settling Op Amp
Pages / Page17 / 2 — AD841* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 380 Kb
AD841* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. DOCUMENTATION
AD841* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES DOCUMENTATION
View a parametric search of comparable parts. • AD841 Material Declaration • PCN-PDN Information
DOCUMENTATION
• Quality And Reliability
Application Notes
• Symbols and Footprints • AN-402: Replacing Output Clamping Op Amps with Input Clamping Amps
DISCUSSIONS
• AN-417: Fast Rail-to-Rail Operational Amplifiers Ease View all AD841 EngineerZone Discussions. Design Constraints in Low Voltage High Speed Systems • AN-581: Biasing and Decoupling Op Amps in Single
SAMPLE AND BUY
Supply Applications Visit the product page to see pricing options.
Data Sheet
• AD841: Military Data Sheet
TECHNICAL SUPPORT
• AD841: Wideband, Unity-Gain Stable, Fast Settling Op Amp Data Sheet Submit a technical question or find your regional support number.
TOOLS AND SIMULATIONS DOCUMENT FEEDBACK
• Power Dissipation vs Die Temp Submit feedback for this data sheet. • VRMS/dBm/dBu/dBV calculators
REFERENCE MATERIALS Tutorials
• MT-032: Ideal Voltage Feedback (VFB) Op Amp • MT-033: Voltage Feedback Op Amp Gain and Bandwidth • MT-047: Op Amp Noise • MT-048: Op Amp Noise Relationships: 1/f Noise, RMS Noise, and Equivalent Noise Bandwidth • MT-049: Op Amp Total Output Noise Calculations for Single-Pole System • MT-050: Op Amp Total Output Noise Calculations for Second-Order System • MT-052: Op Amp Noise Figure: Don't Be Misled • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, SFDR, MTPR • MT-056: High Speed Voltage Feedback Op Amps • MT-058: Effects of Feedback Capacitance on VFB and CFB Op Amps • MT-059: Compensating for the Effects of Input Capacitance on VFB and CFB Op Amps Used in Current-to- Voltage Converters • MT-060: Choosing Between Voltage Feedback and Current Feedback Op Amps
Document Outline Features Applications Connection Diagrams General Description Product Highlights Revision History Specifications Absolute Maximum Ratings Thermal Characteristics ESD Caution Typical Performance Characteristics Theory of Operation Offset Nulling Input Considerations AD841 Settling Time Grounding and Bypassing Capacitive Load Driving Ability Terminated Line Driver Overdrive Recovery Outline Dimensions Ordering Guide
