Datasheet AD841 (Analog Devices) - 7
DescriptionWideband, Unity-Gain Stable, Fast Settling Op Amp
Pages / Page17 / 7 — AD841. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. E (V). mA). ( NT. …
RevisionC
File Format / SizePDF / 380 Kb
AD841. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. E (V). mA). ( NT. E R D. VIN. -MO. CURRE NT. MMO. PU IN. SUPPLY VOLTAGE (±V). ) V. G (. µ (
AD841 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS E (V) mA) ( NT E R D VIN -MO CURRE NT MMO PU IN SUPPLY VOLTAGE (±V) ) V G ( µ (
TA = 25°C and VS = ±15 V, unless otherwise noted.
20 12 E (V) 15 G 10 N mA) A ( NT E R D VIN -MO 10 8 N CURRE NT MMO CE O S C E T 5 UI 6 Q PU IN 0 4 0 5 10 15 20
004
0 5 10 15 20
007
SUPPLY VOLTAGE (±V)
1340- 1340- 1
SUPPLY VOLTAGE (±V)
1 Figure 4. Input Common-Mode Range vs. Supply Voltage Figure 7. Quiescent Current vs. Supply Voltage
20 6 ) V 15 A) G ( µ ( 5 WIN NT S VOUT GE 10 CURRE OLTA AS T V BI U 4 UT TP 5 INP OU 0 3 0 5 10 15 20
005
–60 –40 –20 0 20 40 60 80 100 120 140
008
SUPPLY VOLTAGE (±V)
1340- 1340- 1
TEMPERATURE (°C)
1 Figure 5. Output Voltage Swing vs. Supply Voltage Figure 8. Input Bias Current vs. Temperature
30 100 25 p) p- V ) 10 ±15V SUPPLIES G ( 20 WIN S GE 15 1 PEDANCE IM OLTA 10 PUT T V U UT O TP 0.1 OU 5 0 0.01 10 100 1k 10k
006
10k 100k 1M 10M 100M
009
LOAD RESISTANCE (Ω)
1340- 1340- 1
FREQUENCY (Hz)
1 Figure 6. Output Voltage Swing vs. Load Resistance Figure 9. Output Impedance vs. Frequency Rev. C | Page 6 of 16 Document Outline Features Applications Connection Diagrams General Description Product Highlights Revision History Specifications Absolute Maximum Ratings Thermal Characteristics ESD Caution Typical Performance Characteristics Theory of Operation Offset Nulling Input Considerations AD841 Settling Time Grounding and Bypassing Capacitive Load Driving Ability Terminated Line Driver Overdrive Recovery Outline Dimensions Ordering Guide
