LTC1278 UUUPI FU CTIO SARD (Pin 20): READ Input. This enables the output IN (Pin 1): Analog Input. 0V to 5V (Unipolar), ±2.5V (Bipolar). drivers when CS is low. VCS (Pin 21): The CHIP SELECT input must be low for the REF (Pin 2): 2.42V Reference Output. Bypass to AGND (10µF tantalum in parallel with 0.1µF ceramic). ADC to recognize CONVST and RD inputs. AGND (Pin 3): Analog Ground. BUSY (Pin 22): The BUSY output shows the converter status. It is low when a conversion is in progress. D11 to D4 (Pins 11 to 4): Three-State Data Outputs. D11 is the Most Significant Bit. VSS (Pin 23): Negative Supply. – 5V for bipolar opera- tion. Bypass to AGND with 0.1µF ceramic. Analog DGND (Pin 12): Digital Ground. ground for unipolar operation. D3 to D0 (Pins 13 to 16): Three-State Data Outputs. AVDD (Pin 24): Positive Supply, 5V. Bypass to AGND DVDD (Pin 17 ): Digital Power Supply, 5V. Tie to AVDD pin. (10µF tantalum in parallel with 0.1µF ceramic). SHDN (Pin 18): Power Shutdown. CONVST (Pin 19): Conversion Start Signal. This active low signal starts a conversion on its falling edge (to recognize CONVST, CS has to be low). UUWFU CTIO AL BLOCK DIAGRA CSAMPLE A AV IN DD ZEROING SWITCH DVDD 2.42V REF VSS (0V FOR UNIPOLAR MODE V OR –5V FOR BIPOLAR MODE) REF 12-BIT CAPACITIVE DAC COMPARATOR 12 AGND 12 D11 SUCCESSIVE APPROXIMATION • OUTPUT LATCHES • REGISTER • DGND D0 LTC1278 • BD INTERNAL CONTROL LOGIC CLOCK SHDN CONVST RD CS BUSY 7
