Datasheet LTC1278 (Analog Devices) - 8
Description12-Bit, 500ksps Sampling A/D Converter with Shutdown
Pages / Page16 / 8 — TEST CIRCUITS. Load Circuits for Access Timing. Load Circuits for Output …
File Format / SizePDF / 290 Kb
TEST CIRCUITS. Load Circuits for Access Timing. Load Circuits for Output Float Delay. W U. TI I G DIAGRA S. CS to RD Setup Timing
TEST CIRCUITS Load Circuits for Access Timing Load Circuits for Output Float Delay W U TI I G DIAGRA S CS to RD Setup Timing
LTC1278
5V 5V 3k 3k DBN DBN DBN DBN 3k CL CL 3k 10pF 10pF DGND DGND DGND DGND A) HIGH-Z TO VOH (t8) B) HIGH-Z TO VOL (t8) A) VOH TO HIGH-Z B) VOL TO HIGH-Z AND VOL TO VOH (t6) AND VOH TO VOL (t6) 1278 • TA08 LTC1278 TA08
W U W TI I G DIAGRA S CS to RD Setup Timing CS to CONVST Setup Timing SHDN to CONVST Wake-Up Timing
CS CS SHDN t1 t2 t3 RD CONVST CONVST LTC1278 • TC01 LTC1278 • TC02 LTC1278 • TC03
U U W U APPLICATIONS INFORMATION CONVERSION DETAILS
SAMPLE The LTC1278 uses a successive approximation algorithm C SI SAMPLE SAMPLE and an internal sample-and-hold circuit to convert an A – IN analog signal to a 12-bit parallel output. The ADC is HOLD complete with a precision reference and an internal clock. + CDAC COMPARATOR The control logic provides easy interface to microproces- DAC sors and DSPs. (Please refer to the Digital Interface VDAC S section for the data format.) A R Conversion start is controlled by the CS and CONVST inputs. At the start of conversion the successive approxi- 12-BIT LATCH mation register (SAR) is reset. Once a conversion cycle LTC1278 F1 has begun it cannot be restarted.
Figure 1. AIN Input
During conversion, the internal 12-bit capacitive DAC offset is nulled by the feedback switch. In this acquire output is sequenced by the SAR from the most significant phase, a minimum delay of 200ns will provide enough bit (MSB) to the least significant bit (LSB). Referring to time for the sample-and-hold capacitor to acquire the Figure 1, the AIN input connects to the sample-and-hold analog signal. During the convert phase, the comparator capacitor during the acquire phase, and the comparator feedback switch opens, putting the comparator into the 8
